1970 to 1973 Exhaust tips......The same?
Old 12-01-2004, 03:35 PM
TonyQT
TonyQT's Avatar
Default 1970 to 1973 Exhaust tips......The same?
Are the exhaust tips the same for 1970 to 1973? How hard is it to find original ones, not the SS reproductions? Thanks for the insight.
Old 12-01-2004, 03:38 PM
kdf1986
kdf1986's Avatar
Hello, the exhaust tips for the 1973 are unique to that year. They way they are mounted to the muffler has an angle on it that is different from the earlier models. The 73 will not fit the 70-72 model. I think the muffler is different for the 73 which is why the exhaust tips are different.
When looking for a new set for my 73 I went with the SS tips, since that is all I could find. Then I found out that my cars mufflers were replaced with 70-72 mufflers and the tips will not fit. So I either have to install new mufflers, or get new tips.
kdf 1973 454
kdf 1986 L98
Old 12-01-2004, 03:43 PM
djcwardog
djcwardog's Avatar
The tips are unique for 1973 cars. I replaced my old mufflers with the ones Dynomax lists for the 1973 Corvette - bought from MidAm. I had both kinds and ended up using 1973 tips and the installation hardware for the 1972 cars. Although the inlet is 2.5", the outlet on those Dynomax mufflers seems to be a bit small - maybe only 2.25" across? My tips crimped in a bit (only on the round part - can't see at all unless you look behind the rectangular part) as I tightened them down. I also had to bend the angle in a bit on both sides after tightening - piece of cake - they look stock!
Old 12-01-2004, 04:12 PM
Edzred72
Edzred72's Avatar
[QUOTE=TonyQT]Are the exhaust tips the same for 1970 to 1973? How hard is it to find original ones, not the SS reproductions? QUOTE]
Not hard to find. Ebay has em. Be prepared to pay $$$$
Eddie
Old 12-01-2004, 04:57 PM
sray454
sray454's Avatar
Since you have a '71 the 70-72 is what you want.
You have the following choices...
1. Reproduction and readily available, but are only "similar" to the originals. They are made of a very thin stainless and are 'flared' a bit too much on the upper lip. But they do look good and are - relatively - cheap.
2. GM Service Replacements - Hard to find but constructed correctly. They are made of a flash chromed carbon steel, will have a weld along the bottom but not around the back edge, and will be stamped with a "W" ( for Walker Maffler - the manufacturer ) and the GM part number. They will also have a alignment notch cut into the top of the pipe.
3. Original Tips - Almost impossible to find. They are also flash chromed carbon steel, and have welds along the bottom AND around the back, and have "NO" part number stamping. They too have the alignment notch cut into the top of the pipe.
Old 12-01-2004, 05:19 PM
TonyQT
TonyQT's Avatar
Looks like I have 1 service replacement. Looking at the picture, I think it's for a 73 not a 70-72? Is that right?
Old 12-01-2004, 05:32 PM
sray454
sray454's Avatar
You're correct - you have a service replacement '73 RH tip there ... don't throw it away ... it is a 1 year only, NOS tip ... it is worth a few bucks to a '73 owner ...
Old 12-01-2004, 09:43 PM
carl a
carl a's Avatar
the pipe is centered on a 73 tip-others were off to one side- ill take those tips if your lookin to unload them,,, i have non 73 tips on my car,,,,-someone was giving a set away last year or so, i stalled and lost them to another forum member note how pipe is not centered in photo below------
Old 12-01-2004, 09:59 PM
68435roadster
Guest
Posts: n/a
I happen to have 2 or 3 sets of original '73 exhaust tips. anyone who may be interested can e me for photos, descriptions, etc.. G.
Old 12-02-2004, 02:41 PM
carl a
carl a's Avatar
68435 roadster,,,,,,id like to see a photo of a nice set of these!-------------
To 1970 to 1973 Exhaust tips......The same?
Quick Reply: 1970 to 1973 Exhaust tips......The same?
