Under/Over Steer
Old 09-23-2004, 03:03 PM
kromberg
kromberg's Avatar
Default Under/Over Steer
How bad would the under/over steer be with the 255/40/17s up front with 345/30/18s in the rear? Also a 255/40/17 should fit on 17x8.5 rim right? TIA.
Keith
Old 09-23-2004, 03:21 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,394 Likes on 747 Posts
1. HUGE understeer
2. Yes, 255s will fit on stock front wheels.
The C5s understeer with a 245/275 f/r split. Adding 70mm to the rears without going to at least a 275 up front (which will also work nicely on 8.5 rims) will make the situation much worse.
I'm changing over to a 275/315 split for autocross, but haven't had a chance to try it yet. I'm expecting a small amount of understeer, but hopefully will cure my oversteering problem (currently running 275s all around).
HTH, and have a good one,
Mike
Last edited by VetteDrmr; 09-23-2004 at 03:22 PM. Reason: didn't see the "over" part of the question
Old 09-23-2004, 03:27 PM
vette.se
vette.se's Avatar
Keith
I'm running 285/30*18 (18*10 wheel) front and 345/30*18(18*12 wheel) rear and have understeer, will go for 295/30*18(18*11 wheel) front next season.
Old 09-23-2004, 04:12 PM
kromberg
kromberg's Avatar
I guess another thing is that I do not road race or autocross the car. The main convern with this combo would be 'normal' city street and highway driving.
Keith
Old 09-23-2004, 04:22 PM
JeffC5
JeffC5's Avatar
Location: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I always get understeer and oversteer mixed up. Can someone tell me what each is?
Thanks,
Jeff
Old 09-23-2004, 04:26 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
Thanks,
Jeff
Understeer= front end "pushes" at the limit.
Oversteer= rear end "comes around" at the limit.
Old 09-23-2004, 04:34 PM
VetteDrmr
VetteDrmr's Avatar
Keith
Well, if you're getting into any significant understeer on the streets, you're probably going WAY TOO FAST!. Ditto oversteer in the middle of a corner.
Now, with 345s out back, you probably won't have much problem with power oversteer, except in a tight corner (like an intersection).
Curious, why are you running such huge tires on the rears?
Old 09-23-2004, 04:41 PM
kromberg
kromberg's Avatar
Just about to fire the new combo up: 402 Stroker with a F-1R Procharger. I also have 3.90:1 gears and 3800 stall converter. I am hoping the 345 DR will give some type of traction
Keith
Old 09-23-2004, 04:45 PM
JakeL
JakeL's Avatar
Just IMO, but I'd look elsewhere to solve your understeering problem. I, and many others are running a non-staggered tire size arrangement (same size front as rear - 315/35-17, in my case) without issue - in fact, the car is astoundingly good this way (big smiles!)
Perhaps you need to adjust your rear toe (1/8" in works well), rear camber (more is better up to around 1.5 or 1.6*), too much rake (try lowering the back of the car a bit), too much rear rebound in the shocks (try softening the rear rebound), or, perish the thought , an overly ambitious right foot? Is it corner entry oversteer, corner exit, mid-corner, or transitions/slaloms?
Keith - just puttering around on the street, I'm sure understeer won't be a problem - it's tough (not to mention irresponsbile) to push a C5 hard enough on the street that you approach its limits.
Advice worth the electrons used to make it,
-Jake
Old 09-23-2004, 05:02 PM
Umrswimr
Umrswimr's Avatar
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
I think your traction problems far outweigh any oversteer/understeer concerns you will have. You're gonna be makign huge power and need the big rear tires. I would look into running 275's on the front if you can.
Additionally, you can adjust the balance of the car with suspension changes. Go to a stiffer rear bar, for example.
Old 09-23-2004, 05:35 PM
kromberg
kromberg's Avatar
LOL I love that little gold nugget of wisdom.
Keith
Old 09-23-2004, 10:59 PM
VetteDrmr
VetteDrmr's Avatar
Keith
Good grief! With that kind of torque, power, and traction on the street, you'll start getting bills from the city for road repair!
Have a good one,
Mike
Old 09-23-2004, 11:09 PM
VetteDrmr
VetteDrmr's Avatar
-Jake
Driver problems? NEVER!!! Gotta be an equipment problem! The problem is usually corner exit, sometimes mid-corner. I just have to feather that throttle more than I want.
I might have a bit too much rake, and it wouldn't hurt to get an alignment. Shocks are stock Z51, about a year old.
Any other ideas?
Sorry for the thread hijack, but hopefully it'll help others.
Have a good one,
Mike
To Under/Over Steer
Quick Reply: Under/Over Steer
