Corvette LS1 heads vs 99 Trans Am LS1 heads?
Old 04-30-2004, 03:44 PM
VettesandZs
VettesandZs's Avatar
Default Corvette LS1 heads vs 99 Trans Am LS1 heads?
Will an LS1 head off a 99 Trans Am fit and work on a 98 Corvette? I got a good deal on a set to have ported to put on my 98 Vet, but before I get the port work done, I want to make sure they are exact replacements. Any help would be appreciated.
Thanks
Old 04-30-2004, 03:49 PM
ROD BROWN
ROD BROWN's Avatar
Default Re: Corvette LS1 heads vs 99 Trans Am LS1 heads? (VettesandZs)
i don't know,but I would look on the heads and see if they have the same part number.That way you know you have the same heads,or maybe a telephone call to the Cevrolet Parts counter.I am sure they could help you also. :chevy :chevy :flag :chevy :chevy
Old 04-30-2004, 03:56 PM
rwj383
rwj383's Avatar
Default Re: Corvette LS1 heads vs 99 Trans Am LS1 heads? (ROD BROWN)
yes, they will work. Be sure to get the same model year head gasket, especially if the heads are 853 castings with the dimple in the deck face at the #6/#3 cyl position. If you have these heads you will need the composite head gasket p/n# 12498543. If you use later model mls gaskets with these heads, you may develop a coolant leak.
Robert http://www.gen3motorsports.com
Old 04-30-2004, 04:01 PM
Joe Vinci
Joe Vinci's Avatar
Default Re: Corvette LS1 heads vs 99 Trans Am LS1 heads? (rwj383)
You will also need different valve covers, coil mounting brackets and bolts. 98 heads are perimeter bolts for the valve covers and 99 and up are center bolt mounted valve covers.
Old 05-07-2004, 02:51 AM
VettesandZs
Default Re: Corvette LS1 heads vs 99 Trans Am LS1 heads? (Joe Vinci)
Ok, so there are some differences. Then would 98 C5 LS1 heads be the exact same as a 98 F body LS1? Maybe I can trade them off. Any input would be appreciated.
Thanks Again
Old 05-07-2004, 09:36 AM
Dope
Resident moron
Support Corvetteforum!
Dope's Avatar
98 Y-body == 98 F-body. After 98, they both got centerbolt valve covers with a different coil pack mounting setup.
Dope
Old 05-07-2004, 05:18 PM
VettesandZs
Default Re: Corvette LS1 heads vs 99 Trans Am LS1 heads? (Dope)
Thanks Dope. It figures that the deal I found ends up not such a deal when things don't all fit right.
To Corvette LS1 heads vs 99 Trans Am LS1 heads?
Quick Reply: Corvette LS1 heads vs 99 Trans Am LS1 heads?
