Digital Fuel Pressure Gauge pics
Old 09-27-2003, 02:57 PM
VetteNoob
VetteNoob's Avatar
Default Digital Fuel Pressure Gauge pics
Just got this installed. What do you think?
lead foot 85 vet, your AM FP gauge is shipping out Monday.
Old 09-27-2003, 02:59 PM
AGENT 86
AGENT 86's Avatar
Default Re: Digital Fuel Pressure Gauge pics (VetteNoob)
:cool:
Looks Good !!!!
:cheers:
Old 09-27-2003, 03:00 PM
tlc85
tlc85's Avatar
dang where can i get one
Old 09-27-2003, 03:01 PM
tjwong
Support Corvetteforum!
tjwong's Avatar
Default Re: Digital Fuel Pressure Gauge pics (AGENT 86)
Looks cool how does bright sunlight affect it?
Old 09-27-2003, 03:03 PM
VetteNoob
VetteNoob's Avatar
You can get them from http://www.DynoTune.org. I havent driven the car since installing it so I'm not sure how sunlight would affect visibility yet. I'll let you know in a few hours.
[Modified by VetteNoob, 2:03 PM 9/27/2003]
Old 09-27-2003, 03:15 PM
Bluevette85
Bluevette85's Avatar
I bought from them too and but got the rectangular display that I'll mount on the dash bezel. Fuel rail fittings are on order and should be in tuesday :cheers:
[Modified by Bluevette85, 3:15 PM 9/27/2003]
Old 09-27-2003, 03:16 PM
Caboboy
Caboboy's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
'23-'24
Noobster, that is too sweet! :cheers:
Damn, stuff like this always ends up costing me money :leaving:
Old 09-27-2003, 03:25 PM
VetteNoob
VetteNoob's Avatar
You REALLY need to get the 2 1/16" gauge pod bezel. The thing is billet aluminum and the quality is amazing. When you install yours, make sure to not run the wiring harness ANYWHERE next to your spark plug wires. The harness picks up the electrical pulses and makes the display reading unreliable.
I routed mine under the plenum, then under the driver side injector harness, around the rear of the valve cover and connected the plug at the brake booster.
Tim, Im just trying to help you spend some money is all :yesnod:
Old 09-27-2003, 03:33 PM
scorp508
scorp508's Avatar
Does it dim when the headlights are on?
Old 09-27-2003, 04:13 PM
0ski_dwn_it
Former Vendor
ski_dwn_it's Avatar
Default Re: (scorp508)
Ording one right now! Been wanting one of these items for the longest time!
Can you do me a favor and see how accurate it is again a conventional gage?
32.5 psi seems extremely low, or is that a bad reading, ie car off?
Looks great though!
Old 09-27-2003, 04:43 PM
Bluevette85
I have my Valantine 1 remote display mounted the same way so it's easy to see. I wonder if wrapping the wire with foil or some other type of shielding would cut down on the interference? I'm going to look at the supplied cable to see if it is shielded. It not a trip to radio shack should solve that problem.
Old 09-27-2003, 05:32 PM
VetteNoob
VetteNoob's Avatar
Scorp, the way it is wired up right now, it doesnt. Im not sure what would happen if I wired the 12v power source to a dimmer source. I suppose I can try and just seel what happens
Old 09-27-2003, 05:36 PM
VetteNoob
VetteNoob's Avatar
Default Re: (ski_dwn_it)
It's reading about what my old conventional gauge read but to the ".x" psi. 32.5 is with the vaccum connected and the car in idleing park. Is that too low? It is about 42ish with the vaccum disconnected.
Old 09-27-2003, 05:37 PM
VetteNoob
VetteNoob's Avatar
Default Re: Digital Fuel Pressure Gauge pics (Bluevette85)
The cable is definitely NOT shielded. You may be able to correct the problem if you insulated the wires.
Old 09-27-2003, 05:42 PM
scorp508
scorp508's Avatar
What size/brand injectors do you have?
Old 09-27-2003, 05:51 PM
VetteNoob
VetteNoob's Avatar
Default Re: Digital Fuel Pressure Gauge pics (scorp508)
Holley 24lb injectors.
To Digital Fuel Pressure Gauge pics
Quick Reply: Digital Fuel Pressure Gauge pics
