What are the symptoms of a bad IAC valve/motor?
Old 08-15-2003, 04:20 AM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default What are the symptoms of a bad IAC valve/motor?
Title says it all. I changed several things out and fixed my nasty rich problem. But I still don't know what caused it.
The IAC was definitely broken, pintle jammed out, and the vette would barely run. It got 12 mpg at cruise, sounded lilke it was firing 10 degrees retarded on 6 cylinders, and spit raw fuel into the exhaust when lettting off the throttle.
I guesss i'll put my broken iac back on tomorrow to see if it acts up again. If that's the case, then i chickened out and took my new injectors back off when i shouldn't have.
CentralCoaster is offline
Old 08-15-2003, 04:32 AM
Darkness
Darkness's Avatar
Default Re: What are the symptoms of a bad IAC valve/motor? (CentralCoaster)
I had the same problem a few months ago and it starts to surge when idling or when your driving normal and put it in neutral, some times the engine dies. But it only happened at low rpms, i.e 1000rpm or less.
Later
Darkness is offline
Old 08-15-2003, 05:46 AM
NanoBrain
NanoBrain's Avatar
Default Re: What are the symptoms of a bad IAC valve/motor? (Darkness)
A bad IAC, especially on a MAF vehicle can cause all kinds of drivability issues. The most common symptoms are surging/hunting idle, or an idle that’s way out of spec (400rpm, or 1500rpm), stalling when coming to a stop, causing the ECM to have an erratic integrator value, accompanied with a moderately swinging A/F ratio. Your description of having an extremely rich A/F & “spitting raw fuel out” on de-acceleration, I would not associate that with a bad IAC! Sounds like you installed much larger Lbs/Hr injectors than stock, didn’t adj the fuel pressure, &/or install a custom chip. Perhaps you have a (NEW) bad injector(s) that leaks or are stuck open? The Accel injectors have gained a bad rep already for leaks and serious performance degradation over short periods of operation!
BTW: running that rich will ruin you engine fast, don’t’ drive it till ya fix it!
Just my 2-cents!
:crazy:NanoBrain:crazy:
NanoBrain is offline
Old 08-15-2003, 08:51 AM
AGENT 86
AGENT 86's Avatar
I don't see any relationship between IAC and your problems. IAC affects idle quality and stability only. It sure sounds like problems with those injectors.
Hope you get solved soon Kevin. Good Luck :cheers:
AGENT 86 is offline
Old 08-15-2003, 04:21 PM
jennykayes84vette
jennykayes84vette's Avatar
Okay here's a question for you all. My wife and I have an 84 vette stock no mods has the same surging and dieing issue at below 1000 rpm's I know that the car is running rich, what are the solutions. I know 84's do not have a MAF in them does anyone have an idea. I found that the EGR Valve Silonoid connector is pretty bad. Still making connection but not a pretty site. It is kinda of a search and destroy mission with this car since it is new to us and we are learning the 84 crossfire "quarks". Please help looking forward to getting back to 2 vehicles again. :banghead:
jennykayes84vette is offline
Old 05-06-2012, 09:10 PM
BWD111
BWD111's Avatar
What about engine reving to max rpm at start up. I pulled my out it was very dirty, so I cleaned it and put it back in and had the same result. But this could be a symtom of bad IAC.
BWD111 is offline
Old 05-06-2012, 10:47 PM
H P Bushrod
Moderator
H P Bushrod's Avatar
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
Read the rules about reviving a thread over 45 days old BWD111.
http://forums.corvetteforum.com/foru...s-or-more.html
H P Bushrod is offline
To What are the symptoms of a bad IAC valve/motor?
Quick Reply: What are the symptoms of a bad IAC valve/motor?
