Need a place to re-chrome my wheels.. any recommendations?
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
My chrome 2000 wheels have chrome starting to peel due to corrosion.. I need someone to strip the wheels, clean and re-chrome..
Anyone with a good experience..?
Thanks
Tom
Thanks
Tom
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Re: Need a place to re-chrome my wheels.. any recommendations? (nevrenuf)
You might try Kuntz Industries in Canada. I believe they are near Toronto. They did all the Cadillac chrome plate wheel business for GM a few years ago and may still be one of GMs sources. There are many platers around but they are not OEM quality. Whomever you go with be sure they use the triple plate process. Ist layer is copper, then 1 or more layers of nickel (this is actually the layer that gives you the corrosion protection), the chrome is just a flash coat for appearance only. If you find a source close to you go and visit them...take a tour of the plant and look at the work they have done in the past (they usually are proud of their work and have examples laying around the office). :cheers:
Tom,
Something you acutually can't do yourself, say it isn't so ;) :lol: :reddevil
Your long lost buddy...
Julie says hi by the way, she came in 2nd at the drag competition at the 50th anniv. in Nashville, where were you?
Thanks
Tom
Thanks
Tom
There are a lot of places that chrome wheels in California. You also could try Wheel Collision Center. They repair wheels and they are in PA. The web address is http://www.wheelcollision.com They can probably help you or at least point you in the right direction.
Re: Need a place to re-chrome my wheels.. any recommendations? (frenchcu)
Call HRE find out how much they want. My Forgelines always went back to the factory for any work unless it was minor curb rash. Also Forgeline was cheaper than the other wheel repair companies.
Rennsport did do a good job locally. However I haven't much out of them in a couple of years.
[Modified by 93Polo, 2:45 PM 7/15/2003]
