C6 oil pan on a C5??
Old 11-08-2012, 11:48 AM
Ksths2
Ksths2's Avatar
Default C6 oil pan on a C5??
I've got a 2002 C5 that has the batwing pan like all do & i'm about to pull the LS1 to put in a new bullet and I want to make sure that this rumor is true.
Can a LS2 or LS3 C6 oil pan fit on a C5 with no mods? I'm assuming I'll need the pickup but will the deflector, gasket, & dipstick stick work from my C5?
Old 11-08-2012, 12:01 PM
AVB
AVB's Avatar
Yes... but you should do your research on it's advantages/disadvantages.
Old 11-08-2012, 02:55 PM
C5Natie
C5Natie's Avatar
Yes the LS2 pan will fit. My friend used one in his 427 build. It also allows you use C6 headers I believe so the market for 1 7/8 primaries is bigger. I stayed with my batwing pan on my LS3 C5 because I believe it controls the oil a lot better especially on high G turns and I do a few hpde a year.
Old 11-08-2012, 03:19 PM
All_Motor_C5LS6
All_Motor_C5LS6's Avatar
this is great information.
Old 11-08-2012, 04:11 PM
Ksths2
Ksths2's Avatar
I've tried to search for advantages/disadvantages but nothing really came up, AVB can you list a few? My car is mainly used for dragracing these days not much hardcore cornering anymore
My main reason for wanting to go with the LS2/3 style is gaining clearance around the headers & front cradle and ease of engine removal.
I've also heard that the C6 style has another quart of oil capacity?
Old 11-08-2012, 04:55 PM
C5Natie
C5Natie's Avatar
This has been discussed in the roadrace section by real racers. Batwing for wet sump systems, LS2/3 for dry sump.
http://forums.corvetteforum.com/auto...5-oil-pan.html
Old 11-08-2012, 06:10 PM
Ksths2
Ksths2's Avatar
no comment on the "real racers"......
Old 11-08-2012, 06:19 PM
C5Natie
C5Natie's Avatar
Not a knock on anyone, just meant guys using either pan for racing applications.
Old 11-08-2012, 10:56 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
American Racing Headers has been making 1.75/.825 and 2.0 inch headers for years in C5 and C6 fitments
The LS2 pan fits in the C5, I have this setup
Old 11-12-2012, 01:16 AM
C5Natie
C5Natie's Avatar
I just said the market is "bigger" for the C6's. You get a few more choices in manufacturers.
Old 11-12-2012, 11:34 AM
Ksths2
Ksths2's Avatar
I ended up buying a "new" take off pan, deflector, dipstick, gasket, and pickup for $235 to my door off of Ebay. Compared to GM prices, other Ebay'ers etc I thought this was a good deal.?!
Very interesting on the C6 headers on a C5.... I'm in need of a set of 2" primaries from American Racing Headers really bad!
Old 11-24-2012, 12:58 AM
ITSQUIK
ITSQUIK's Avatar
I bought a C6 LS3 Oil Pan off a guy that bought a crate motor. It was installed on my '09 LS3 that I am building and will be put in my '97 C5 over the winter.
I am hoping that it fits with no issues. Plus I am all for more clearance for bigger headers. Might need a set down the road.
Old 11-24-2012, 09:23 PM
Bob K
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Support Corvetteforum!
Bob K's Avatar
St. Jude Donor '11-'24
Default It Works
I have a C6 oil pan on my ERL LS3. I changed over because the stroker crank in the 454 required a little more room.
Bob K.
To C6 oil pan on a C5??
Quick Reply: C6 oil pan on a C5??
