Z06 wheels on a coupe
Old 09-12-2012, 03:20 PM
jdk541
jdk541's Avatar
St. Jude Donor '22-'23
Default Z06 wheels on a coupe
Can anyone tell me if the stock wheels from a 2008 Z06 would fit directly on a 2006 coupe? Are the wheel / tire sizes the same?
Old 09-12-2012, 03:30 PM
RicK T
RicK T's Avatar
"Fit" is a relative term. Yes they will bolt up. The Z06 wheels and tires are wider than the base car and the offsets are different which pushes them even further out. So you could use them but you run the risk of damaging the fenders if the suspension compresses far enough on a good bump, etc.
Here is some basic info with pics:
http://forums.corvetteforum.com/1570597582-post7.html
Another pic:
http://forums.corvetteforum.com/1577438136-post13.html
You can successfully use the front Z06 wheels with the standard base car front tires with no problem.
Old 09-12-2012, 03:48 PM
jdk541
jdk541's Avatar
Rick - Thank you for the info... Just saved me a lot of money.
You Rock!
Old 09-12-2012, 04:29 PM
Raazor
Goon Squad King of Battle
Support Corvetteforum!
Raazor's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13x3- '14-'15-'16-'17-'18-'19-'20-'21-'22-'23
you can purchase wheels that LOOK like the Z06 wheels and fit the standard body corvette.
Old 09-12-2012, 04:33 PM
jdk541
jdk541's Avatar
I think that is what I am going to do unless someone comes up with a deal that is just too good to pass up. I need to get these stock aluminum wheels off this car as soon as possible.
Just my opinion, but I think the chrome Z06 wheels are the best looking ones on the road.... But you know what they say about opinions.
Old 09-12-2012, 05:03 PM
ulllovethecarpayment
ulllovethecarpayment's Avatar
when you take them off PM me; I have a bent wheel if you're selling I might be willing to take them off your hands
Old 09-12-2012, 05:58 PM
da_vato
da_vato's Avatar
Go to 1stratecorvetteparts.com Keith's customer service is top notch
Old 09-12-2012, 06:06 PM
jdk541
jdk541's Avatar
When I get the new wheels, I will have no use for these and I will be looking to sell. I will PM you.
Old 09-12-2012, 06:44 PM
ncvette_1FUNRIDE
ncvette_1FUNRIDE's Avatar
2015 C6 of the Year Finalist
You might want to consider Ace Slick wheels. They look very similar to the older Z06 wheels but are made to fit a regular coupe. They are 1 inch wider in the front and back but fit just fine.
Here's what they look like. Also you can get a set for under $900 I believe. You can get these in chrome or Hyperblack (looks like silver though).
Old 09-12-2012, 06:51 PM
haljensen
haljensen's Avatar
All wheels for the C6, GS and Z06 are aluminum, only the style, size and finish differ. It's been many years since a wheel made of anything but aluminum was available for a Corvette.
Old 09-12-2012, 06:54 PM
jdk541
jdk541's Avatar
Understood. When I said aluminum, I meant the flat "painted aluminum" finish that is dull and boring. I am looking for chrome as it really seems to make the color of the Corvette, whatever color it is pop.
BTW - I sent an e-mail to Keith at 1stratecorvetteparts as suggested above and he already called back with a really good quote. Thank you for the tip.
Old 09-12-2012, 06:59 PM
ncvette_1FUNRIDE
Old 09-12-2012, 07:02 PM
jdk541
jdk541's Avatar
Originally Posted by ncvette_1FUNRIDE
Thank you for the further inspiration. That is the EXACT look I am trying to acheive!
Old 09-12-2012, 07:26 PM
VETFEVER
VETFEVER's Avatar
And a bonus with the ACE Alloys "Slick" wheel is that you can install Z06 brakes on your base coupe with no clearance issues.
Old 09-12-2012, 07:30 PM
VETFEVER
VETFEVER's Avatar
Like this....
Old 09-12-2012, 07:31 PM
VETFEVER
VETFEVER's Avatar
After I took these pics I bought some C6 decals for the centre caps that finished the look....
Old 09-12-2012, 07:34 PM
VETFEVER
VETFEVER's Avatar
Of course, another option are the TSW Nurburgring wheels I currently run - these are 19/20 inch and also clear the big brakes...
To Z06 wheels on a coupe
Old 09-12-2012, 07:40 PM
ncvette_1FUNRIDE
Yes, I forgot about that. Ace Slicks will clear Z06 brakes and you can use your stock OEM tires.
Old 09-12-2012, 11:02 PM
Thank you very much! In the mean time; send me a price quote? Also, have you checked the forum vendors? They have some really nice wheels out there for a bargin. Chrome Spyders come to mind from.. um.. f*&^ I forgot his name
Old 09-13-2012, 08:37 AM
Turbo6TA
Turbo6TA's Avatar
Received 3,066 Likes on 2,073 Posts
House of Wheels
Here is the link to there reproduction wheels (you will also see the chrome "Spider" wheels there):
Make sure you get the correct offset for your car
http://www.houseofwheelsonline.com/corvette_copies.php
Quick Reply: Z06 wheels on a coupe
