72 LT-1 Intake manifold bolts
Are you sure that you don't mean the two front left (driver side) bolts?
Those two are definitely longer by a 1/4" or so as they had to pass through the engine lift bracket. Headmarks are typically different as well.
If you actually meant the right side, I'm at a loss... Why would they need to be different?
Regards,
Stan Falenski
Regards,
Stan Falenski
same here, whats special about right side, check this 1 1/4" for 10 and 1 3/8" for 2
https://www.paragoncorvette.com/p-35...-bolt-kit.aspx
I think the very front bolt goes into a blind hole and the second one is open to the lifter valley? Just be careful that they do not bottom out or strike the push rods. Length depends on lift bracket also. mike...
That's why I'm asking. I removed both RIGHT FRONT bolts and the front one is about 1/4 inch shorter. I thought they should be the same.
The front one doesn't look stock and I was wondering if I could put a 1 1/8" long bolt in there.
Thanks guys.
Thanks guys.
