borg Warner trans
borg Warner trans
What years did corvettes come with the T10s
AND WERE THERE EVER A OPTION THAT CAME WITH A BORG wARNER TRANS WITH A GLIDE ATTACHED 4PLUS2 ?
OR SOMETHING OF THAT NATURE
Looks like the Doug Nash 4+3 used from 1984-88 was also based on the T10.
http://forums.corvetteforum.com/c3-t...er-t-10-a.html
74 and later Vettes had GM specs T10 transmissions. I won't call them "super" because the gearsets weren't the special high nickle gears used in aftermarket Super T10s.
The C4 Vette had a 4+3 overdrive transmission designed by Doug Nash that used an auxillary planetary gearset like an auto transmission uses. The 4 speed section of the 4+3, is basically a GM T10 transmission.
Received 4,558 Likes
2021 C8 of the Year Finalist Unmodified
2019 C1 of Year Winner (performance mods)
2017 Corvette of the Year Finalist
2016 C2 of Year
2015 C3 of Year Finalist
I had a 4 plus 3 tranny in an 85 Corvette I owned a few years ago. Essentially a Borg Warner T-10, 4 speed coupled to a Doug Nash overdrive unit. It's design was flawed and problematic. 2nd, 3rd and 4th gears had overdrive which widened the gear ratio. It made for lower RPM cruising on the highway. Most that owned them switched them out for 5 or 6 speeds. Parts are hard to come by and nobody knows how or wants to work on them.
