C6 Parts for Sale/Wanted C6 Corvette Performance Parts, OEM, Aftermarket, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements
FS: Nick Williams 102mm throttle body for C5 &C6
Old 02-19-2012, 11:40 PM
regorih
regorih's Avatar
Default FS: Nick Williams 102mm throttle body for C5 &C6
Update*4-16-2012
All other did not happen. Im re-listing it again.
Yes, I still have the tb. Its not damaged but its been modified. As you many or not know the C5 style Nick Williams TB needs to have some material taken off the bottom, and on the top of the water pump to make it fit. This TB has already had the procedure done. If you dont believe me look it up. The TB has less than 1k miles and its in tip top shape. Its been repainted and ready to go. Let me know.
Guys I have a used Nick Williams 102mm throttle body that I need to sell. Its ready to be installed on any C5 vehicle since its based around the C5 throttle body (Notice its has the C5 blade motor and throttle possiton sensor and not the C6/LS2/LS3/LS7 design).
Wait....................What do you say.......You have a C6 or some other GM vehicle that came with an 90mm OEM update design throttle body? Not to worry I also have the Casper jumper harness that will allow you to run this C5 based throttle body on almost any 2005+ GM LSX vehicle.
Im asking $388 with the harness, and im asking $390 without the harness.
Let me know,
ROger
Old 02-20-2012, 01:01 AM
NA-Z06
NA-Z06's Avatar
Pm sent
dibs
Old 03-08-2012, 07:36 AM
regorih
regorih's Avatar
Still have it
Old 03-08-2012, 01:14 PM
NA-Z06
NA-Z06's Avatar
Great guy to buy from!
Bump for you.
Old 03-08-2012, 02:25 PM
regorih
regorih's Avatar
Bump for you.
No mames
You coming down or what?
Old 03-08-2012, 02:33 PM
NA-Z06
NA-Z06's Avatar
Originally Posted by regorih
No mames
I doubt it bro. I'm lookin to build the motor instead lol
Old 03-08-2012, 09:02 PM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
Cheaper to buy with the harness than without the harness.
Old 03-10-2012, 10:08 AM
philly07c6
philly07c6's Avatar
is this for sale still
also with the harness this will fit my 07c6
Old 04-16-2012, 11:06 PM
regorih
regorih's Avatar
yes it will fit.
Old 05-09-2012, 09:49 AM
willyfastz
willyfastz's Avatar
Is this still for sale?
To FS: Nick Williams 102mm throttle body for C5 &C6
Quick Reply: FS: Nick Williams 102mm throttle body for C5 &C6
