Seperate cd player
Old 02-14-2012, 11:27 AM
Hoggg
Hoggg's Avatar
Default Seperate cd player
Fellas,
Don't laugh, how do I connect a cd player seperate from any dash use. I want to run a power wire from the battery to a cd player and box speaker to the back of a 66. Sounds easy but I am ready to duck tape my head. I do need a step by step procedure.
Thanks,
Old 02-14-2012, 12:50 PM
C6Matt
C6Matt's Avatar
Originally Posted by Hoggg
Fellas,
Thanks,
You will need to tap in to an ignition signal wire (live when key is in run or acc.) or pick it up at the fuse box. Then you can run a constant "hot" from the battery, or in the fuse box. be sure to put a fuse in the wires, no need to have the hot tunes make the car "really" hot. Then you'll just need a ground (several locatons on the car availble) and run your speaker wires. If you want the am/fm to work you'll need to pull the antenna lead from the factory radio and route it to the new radios location. hope this helps!
Attached is a pic of a 65 fuse block. you can see the post labled "ACC" - run that to the switched power wire (yellow) on the radio. Below it is a "batt" post, run that to the constant on (red) wire on your radio... run a ground and it will power up.
Quick Reply: Seperate cd player
