clutch fork hyper-extending
Old 02-13-2012, 08:50 PM
Impala Balko
Impala Balko's Avatar
Default clutch fork hyper-extending
I posted this video this summer of my 94 6-speed coupe making a god awful grinding sound only when the clutch pedal is pressed all the way to the floor. Everyone said it was the clutch fork was hyper-extending and rubbing against the pressure plate... I was so frustrated I just parked it. Well I want to fix this problem now that its winter and I can take my time with it. Does anyone have a write-up on how to get this tranny out and fix it. Any info would be awesome.
Old 02-13-2012, 09:05 PM
oldalaskaman
oldalaskaman's Avatar
if your clutch works good and releases and engages bout 11/2" above the floor, quit pressing it all the way to the floor
Old 02-13-2012, 10:24 PM
Impala Balko
It's force of habit to mash it to the floor especially if I have to panic stop.... Plus I read it will get worse and possibly damage other things.... That's why I put it in hybernation early.
Old 02-14-2012, 07:55 AM
LD85
LD85's Avatar
If the ball stud works its way out, that can make the fork rub, because the fork is closer to the PP
The stock hydraulics are a fixed stroke, you can't force the fork farther than the stroke of the slave, so something is bent or backed out etc.
Running issues;
1. FW too thick.
2. Ball Stud backed out
3. Bent Fork
4. I guess, a bad TOB
This always reminds me of how much I loooovvvve my TKO600,, Happy Valentines Day TKO, my sweet!!!
Old 02-14-2012, 08:26 AM
LD85
LD85's Avatar
http://forums.corvetteforum.com/c4-t...post1578535204
You know, if you hold he fork down long enough, the noise will go away
Old 02-14-2012, 09:03 AM
oldalaskaman
this shows a fully functional 'drive it like you stole it ' attitude,.....totally excellent
Old 02-14-2012, 09:13 AM
LD85
LD85's Avatar
it pops out of me every now and then
Old 02-14-2012, 04:11 PM
Tommy8770
Tommy8770's Avatar
I have a problem the opposite from yours. I push my clutch all the way in and it doesn't release quite all the way. Put in new clutch,pressure plate, throw out bearing, master cylinder, slave cylinder, new line and have bled the thing till blue in the face still the same thing. Forgot to mention a new engine and yes checked the endplay of the crank. Good luck on yours a least you can drive it. About ready to dig a hole for mine.
Old 02-14-2012, 04:40 PM
LD85
LD85's Avatar
I would have someone get under the car and push in on the fork with a screwdriver or long stick etc, as far as they can and you see if the shifter will shift, if it does, then problem is hydraulics
if it does not, then the hydraulics are good, and you have a geometry problem i.e. stack ups etc
I dont want to make it sound simple, sounds like you've tried everything already
Old 02-14-2012, 04:44 PM
Nathan Plemons
Nathan Plemons's Avatar
The pivot ball is loose. It screws into the bellhousing and it has a locking screw / bolt that screws into it from the back side. I had this problem and when I removed the transmission the locking screw just fell out on the ground.
I found that fortunately the fork was tougher than the pressure plate and so the fork wasn't damaged (I had bought a new clutch to put in it anyway). I cleaned the metal shavings out of the bellhousing and threaded the ball stud back fully in place. I then put the locking screw back in place with locktite this time and put it all back together. I haven't had any trouble in years.
It's a very easy fix that's a real pain just because you've gotta get the trans out of the way. Might as well toss a new clutch in while you're at it, it's only a handful of bolts away by the time you get to the pivot ball.
Old 02-14-2012, 09:38 PM
Impala Balko
How hard is it to get the tranny out then back in.... Do I have to bleed the hydrolics how hard is it to line it up and how hard is it to do this on jackstands vs a lift
Old 02-16-2012, 09:36 PM
Tommy8770
Tommy8770's Avatar
Pain in the behind on jack stands and not bad with a hoist.
Old 02-16-2012, 09:38 PM
Tommy8770
Tommy8770's Avatar
I got my clutch problem fixed. It turned out to be a bad pressure plate. It's nice to drive it again.
To clutch fork hyper-extending
Quick Reply: clutch fork hyper-extending
