Removing Rearview Mirror Plug
Old 02-04-2012, 03:47 PM
Coyvett
Coyvett's Avatar
Default Removing Rearview Mirror Plug
How do you remove the power plug on the back of the rear view mirror. I know there is a tab on top, but I can't get my hand behind it to pull out the plug. I don't want to pull on the power cord for fear of pulling the wires out. Trying to install Blendmount radar detector bracket
Old 02-04-2012, 03:51 PM
franman69
Support Corvetteforum!
franman69's Avatar
I have an 07 Coupe... I turned my mirror facing upwards and was easily able to reach the release tab with my fat fingers and push it while pulling on the connector. Came right out.
AirBusPilot
AirBusPilot's Avatar
Yep, just move the mirror over all the way to the right.
Old 02-04-2012, 04:30 PM
NOMRW8NG
NOMRW8NG's Avatar
Turn the mirror as noted above, but you may also need to wiggle the connector side-to-side while pushing on the tab and pulling it out. On my car it was very snug.
Old 02-05-2012, 05:23 PM
Coyvett
Coyvett's Avatar
When you guys are pulling on the connector, are you pulling on the wires or the connector itself. I can't get a grip on the connector and don't want to pull too hard on the wires. Should not be this difficult.
Old 02-05-2012, 05:34 PM
Knob Jockey
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
You can grab the wires and/or the connector or both together, but you absolutely have to get the tab depressed for either approach to work.
Hold the mirror with your free hand, you don't want to yank it out of it's mount.
And as was stated above, wiggle the connector from side to side. It is a tight fitting connector.
Old 02-05-2012, 07:16 PM
Coyvett
Coyvett's Avatar
Got it. Thanks
To Removing Rearview Mirror Plug
Quick Reply: Removing Rearview Mirror Plug
