'61 Heater Hose
St. Jude Donor '07
Bill
Not trying to re-engineer it just don't need a dump out of coolant on those hot Orlando July days in traffic...
Ya, know, those heater control valves aren't all THAT expensive, and if they leak, they will must likely leak at the plunger rod seal, so iffn it was me, i would replace the damn thing as long as you are under there.
Ain't no fun working under there, and coolant all over your new carpet is a real bummer, and a (most likely) 51 YO part with a rubber seal is waiting for the right time, or jostling, to fail.
I do like Bills idea about a complete copper Ell thru the firewall. Only reason GM didn't do that was rubber hose was cheaper than an extra 6" of copper pipe.
Doug
Doug
It's a reproduction part from some time in the mid 1980s. I had a metal box on there until the cardboard ones were available. I installed it before taking the car to Bloomington in 1990. I can't say how accurate the cardboard one is, but I do remember it being much more expensive than the more durable but incorrect metal box.
Heater control valve has been ordered !
Zip M-2400
you have to do better than that an on an on......do you have another example....or maybe the customers are the ones not smart to pay 10 bucks for a by-pass hose and then shipping....... Get Gates on line,,,,
M2400 is just a 90 degree elbow, not what or even close...... a ordinary by-pass hose......and at 10 bucks is a joke.....you didn`t read my reply very well....the Gates hose has the elbow molded into it and at lengths up to 48 inches long...not a small by-pass hose...appears to be a 396/427 hose......
I was merely pointing out that they all have them. That is all.
Jim
#33
I know that this post is a little old, but I just did my heater hoses on my 59 and it seems that the hoses are much longer than needed, Maybe 6" to 12" to long (at least the 3/4 return). Frank did you have to cut yours down or did you just kind of let them hang by the inner fender?
#34
Yes my 'correct' hoses were a little long...however they shouldn't be 'hanging' anywhere .. there is a double bracket that holds them up under the passenger side of the engine compartment on the fender and they then go from the firewall through the inner fender clamp on to another clamp up under the generator to the engine...not much slack for anything to hang at all.
i also put TWO cut off valves in the heater hoses under the passenger fender and cut them OFF last week and even with the climbing Orlando temps I swear the car runs noticeably cooler and the cockpit as well. Maybe I'm on to something here...
#35
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
I think the extra foot was for the pump to the expansion tank. Hope these photos help off my 62.
#36
However, next question. I tried to save the heater control valve, it's original and has the capillary tube. It leaks. I did buy a replacement valve but it looks significantly different. I'll use the new one if I have to, but does anyone know if the old valves can be repaired and if so, who repairs them?
#37
I don't think you'll find a soul that repairs those...as the capillary tube was eliminated w-a-y back and is not a recent thing with the current repro parts. It just didn't do anything significant. Put the new valve in and keep on truckin.... If its really buggin' ya...you could take a run by Tom DeWitt on here...if he doesn't know anybody then it just ain't gonna happen.
Redbird - we need to talk about your engine bay....I've got some extra GM orange spray paint if you need it!
#38
Frank:
Appreciate the info. A guy on the NCRS forum gave me the name of a guy who sells them on Ebay. I took a look at the pic of the item he sells and the valve looks like the one I bought from CC with the capillary attached. My original (I believe), looks different. It's not black and the cable attachment is sorta round and not square like the repro, also, the capillary is much bigger.
In any event, decided to use the "new" one. Will keep the original and hope some day to find a rebuilder. Thanks again.
Steve
Steve
#39
Jim
#40
Frankie, Can't touch much in the engine bay. Car will be taken to San Diego in June for Star Bowtie judging.
