Holley Throttle Cable Length Question for a '73...
Old 02-03-2012, 08:08 AM
FLA-C3
FLA-C3's Avatar
Default Holley Throttle Cable Length Question for a '73...
I've gone with a Holley on my '73 and picked up one of the LT-1 cable brackets because the stock bracket didn't allow enough throw in the linkage. I have everything hooked up and adjusted now, but the cable has a large dip in it since the attachment point has moved aft on the new bracket. All the vendors only list one cable for 68-73.
For anyone who's made this swap, have you had any issues with this...is that common...ok? The cable/linkage still seems to move freely. Just wondering if I should go with an adjustable length Lokar cable just to be safe.
Old 02-03-2012, 10:13 AM
smyth1
smyth1's Avatar
doing the same thing now .just ordered the holley bracket .you can try a different spot on the throttle lever for the ball stud.
Old 02-03-2012, 11:13 AM
FLA-C3
FLA-C3's Avatar
Smyth1, where the ball stud attaches to the carb is not really the issue. It's that the location where the cable attaches to the bracket is farther aft than before, shortening the distance to the firewall...bunching up the cable. I found an old thread with some photos of the same setup. The last photo shows the same dip in the cable. I guess I'm not gonna worry about it for now.
http://forums.corvetteforum.com/c3-t...et-change.html
Old 02-03-2012, 11:23 AM
RobbSalzmann
Support Corvetteforum!
RobbSalzmann's Avatar
St. Jude Donor '12
I would run the Lokar cable. You don't want to be worrying about a 40 yr old cable that is now flexed differently that it might start binding or worse, stick open. They look nice too.
To Holley Throttle Cable Length Question for a '73...
Quick Reply: Holley Throttle Cable Length Question for a '73...
