Power Side Mirror
Old 12-05-2011, 05:50 PM
cuejack
cuejack's Avatar
Default Power Side Mirror
Hi Guys I've got 1989 Corvette and the mirror on the driver's side seems to move on it's own. I set it everyday, and every morning it has moved back. Any ideas on why? ..... Thanks . Cuejack
Old 12-05-2011, 07:11 PM
SunCr
SunCr's Avatar
Check to see if the motor screws are loose. Should be visible with the mirror in the outer most position.
Old 12-06-2011, 01:40 AM
Cliff Harris
Cliff Harris's Avatar
I found the screws loose on the bracket the motor mounts to. I've seen posts where others said this was their problem.
Sometimes one of the trunion (cross-shaped piece the mirror pivots on) pins comes out of its socket, which will also cause the mirror to wander around.
To Power Side Mirror
Quick Reply: Power Side Mirror
