Side Mirror Options 1965
My side mirror is original with the original glass and is in excellent condition appearance wise. The problem is the mirror will not stay in the position you place it in. It flops down as soon as the wind hits it or you go over a bump. Are there options for rebuilding these?
Thanks
Thanks
Locktight
Thanks
Thanks
You may need to do it again, mostly because the mirror get bumped getting in and out of car. But it will not move because of vibration or wind.
Jack
C2 of Year Finalist (appearance mods) 2019
I used some Loctite super glue and mine has been in the same position for over 3 years without moving. I just used a small dot and it doesn't show at all.
Received 2,126 Likes
If you can carefully remove the glass, then get a spring loaded center punch. Use it all around the area of the ball. Peening the metal will tighten it up. I did this on my '67 several year ago, still hold with good resistance. Dennis
2 cent fix..........
Had same issue with outside and inside mirror .. pushed mirror down to expose as much of ball as possible .. Put one drop of clear nail polish on ball . put mirror back to normal position .. nail polish will add an extra milimeter of coating to ball and was enough so that mirror stays in position .. 4-5 yrs later .. works fine
