C2 Convertible Top Frame
2nd Gear
Hi All,
I have a 1963 Roadster that was missing the soft top when I bought it. It is a dual top car. I have the hard top, but I would like to buy a soft top. I noticed one is being listed for sale locally. It is off a 66 car. My question is, are there date codes or other indicators that would make it obvious the frame is not correct for my car?
Also, the top already has the vinyl top installed since it was pulled off a car which was later sold. Any comments about that? Would I be able to bolt it right on my car or am I over-simplifying? Thanks in advance for your advice.
Received 1,856 Likes
Hi All,
Received 2,126 Likes
If you get the frame, before you have a shop put the new top on, adjust it first too the windows, header latches, and rear pins. Then have the new top installed. Make sure your new one includes pads. If you need weatherstriping, don't be surprised at the cost. The vinyl covered hardtop should bolt right on. Some people have two sets of front latches and some don't. It's up to you on that. A vinyl top was an option on '67 only. So it will depend on what you want too do with your car relative to the top. Dennis
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
I installed my 62's with the cover on it, and it was no problem, BUT make sure you get all the mounting stuff on both ends, and the reinforcement plates at the rear mounting locations if missing. (if there are those on a mid, i forget). The hardware is expensive to buy after the fact, and should reflect in the price accordingly.
I did mine myself, and it would have been a lot easier if you do it with a bud.
