What is the best tool you have found for drilling/cutting rivets on radio brackets?
Old 10-02-2011, 09:04 AM
1FUNC5
1FUNC5's Avatar
Default What is the best tool you have found for drilling/cutting rivets on radio brackets?
What are you guys using to remove those kevlar treated rivets? I know I can take tinsnips and just cut but I dont want the sharp edges inside the dash. I'm wondering if an air drill with a good bit would be suffice? I want the cleanest removal as possible.
Steven
Old 10-02-2011, 09:07 AM
Kamauxx
Kamauxx's Avatar
I used snips after hours of trying and failing with a drill.
I'd say cobalt bits and a right angle dewalt should do it, if you're willing to spend the cash.
Old 10-02-2011, 09:08 AM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I worked with those darn rivets for a long time and didn't get anywhere, I ended using a sawzall.
Old 10-02-2011, 09:19 AM
BobbyC5
BobbyC5's Avatar
I used a Dremmel and ground the heads off. It took no time at all, but have a vacuum handy to clean up the shavings.
Old 10-02-2011, 09:21 AM
1FUNC5
1FUNC5's Avatar
what tip did you use?
Old 10-02-2011, 10:07 AM
capehorn3
capehorn3's Avatar
in my future, what HU did you get?
Old 10-02-2011, 10:17 AM
1FUNC5
1FUNC5's Avatar
kenwood 9980hd, cmos-300 camera, XM (not sirius) receiver, and a leather bezel from Dennis
Old 10-02-2011, 05:38 PM
srs244
Support Corvetteforum!
srs244's Avatar
St. Jude Donor '09-'10-11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
same here. tried it out off frustration, then kicked myself that i didn't go that route in the first place. easy way to do it.
Old 10-02-2011, 07:59 PM
1FUNC5
1FUNC5's Avatar
used a handheld sawzall! worked great... to hell with those damn rivets!
Old 10-02-2011, 08:30 PM
7LitreC5
7LitreC5's Avatar
Die grinder with a carbide bit. Gone in seconds!
Old 10-02-2011, 10:51 PM
ljorges
ljorges's Avatar
When Greg (Pentavolvo) installed my double din, he also used the sawzall. It was super quick and clean. True, I couldn't watch.
Les
Old 10-03-2011, 07:31 AM
Jet-Jock
Jet-Jock's Avatar
I did that same thing but bought a right angle tool for my dremel and used up bunches of the cutting wheels. Buy at least two little boxes of those things. They don't last long.
I stuffed a bunch of rags in there, lots of sparks too, so no flammables around.
The left sides throws the debris into the rags, the right side throws it out at you so I laid larger towel down over the entire console. And a vacuum as little bits gets all over, regardless of how careful.
The bracket doesn't come free after they are removed, you have to tap it some.
HTH
Old 10-03-2011, 09:17 AM
Mikvi
Mikvi's Avatar
St. Jude Donor '10
I used a right angle craftsman drill and cobalt 1/4 bit. Took about 2 minutes. I was lucky in that I already had everything.
To What is the best tool you have found for drilling/cutting rivets on radio brackets?
Quick Reply: What is the best tool you have found for drilling/cutting rivets on radio brackets?
