C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Help, Correct belt size with 10% UD damper?
Old 08-12-2011, 08:14 AM
ALTECH
ALTECH's Avatar
St. Jude Donor '14
Default Help, Correct belt size with 10% UD damper?
Hello,
Can someone please tell me what is the correct belt size to use with the ATI 10% underdrive damper?
Thank you very much
Old 08-12-2011, 11:11 PM
Vette5.5
Vette5.5's Avatar
Dont have an answer as to the size needed, but if you're willing to sacrifice your existing belt, know a way to find out. Jam, or wire the tensioner in position, and cut the belt open. Measure the length difference with the new pulley installed, and there you go. Maybe check the belt manufactures site to decode the belt markings, for finding the actual sizes you're dealing with.
Old 03-15-2012, 07:31 PM
RIRaven
RIRaven's Avatar
Does this seem correct?
Goodyear Gatorback #4060785 for pump,alt,etc and a #4040395 for the a/c
Katech recommends http://store.katechengines.com/gates-belt-p239.aspx
To Help, Correct belt size with 10% UD damper?
Quick Reply: [Z06] Help, Correct belt size with 10% UD damper?
