C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
How to get more torque?
Old 05-28-2011, 12:32 PM
trapp
trapp's Avatar
Default How to get more torque?
After procharger at 6 psi and a cam I'm getting 524rwhp but only 431 tq.
These numbers on my 2011 GS.
My 2009 c6. Had 495/450 ! this was without cam
Adding cam lost tq to my 2011 gs
Any ideas to gain back tq. I was hopeing to get more tq with my new setup.
Any ideas?
Old 05-28-2011, 12:52 PM
Vert_Fan
Vert_Fan's Avatar
One option would be to pulley down and add a restrictor plate in front of the procharger's inlet.
Another is to change cams, revisit the tune..........I'm in for more answers too.
Good luck.
Old 05-28-2011, 02:43 PM
APSGTO
APSGTO's Avatar
At 6psi you are seeing less than 2psi at 3000rpms and 3psi tops at your torque peak. Because of the nature of the boost the centrifugal makes and the large intake runner of your LS3 heads I could see the lower torque and higher HP from the same pulley/blower setup. At lower boost levels the boost dosn't really start to kit in until the torque peak of the stock cam has passed. Hence the wide gap between HP and torque. It is not uncommon to see a 90-110 rwhp-rwtq gap on centri S/C's.
Definatly talk to ECS about pulley down and using a restrictor plate, should help big time. Be prepaired to run meth injection due to the extra heat the restrictor plate creates.
Old 05-28-2011, 03:55 PM
winters97gt
winters97gt's Avatar
Meth is not a bad idea. I gained 80rwtq with it. Fealt like adding a small shot to the car.
Old 05-28-2011, 04:10 PM
carlrx7
carlrx7's Avatar
St. Jude Donor '08-'09
no way in hell a supercharged engine should be making less tq than his previous na combo. tune or cam is wrong
Old 05-28-2011, 04:15 PM
trapp
trapp's Avatar
Previous car was a base c6 with procharger at 6 psi
Current car 2011 gs with same procharger but added different cam...
Both had/have kook headers/cats
Old 05-28-2011, 05:41 PM
APSGTO
APSGTO's Avatar
Well with only 6psi at 6500rpms on the stock long block, I'd say a max effort H/C car could put down more peak torque.
OP look into some LG Superpro 1 3/4" headers, they gain big gobbs of torque down low. About 20rwtq at 4000rpms over Kooks LT's.
Old 05-28-2011, 06:56 PM
MARSC6
MARSC6's Avatar
That seems very low. Might want to look into another tuner.
Old 05-28-2011, 08:39 PM
old motorhead
old motorhead's Avatar
Received 1,339 Likes on 947 Posts
Cam specs?
Old 05-28-2011, 09:08 PM
trapp
trapp's Avatar
Originally Posted by old motorhead
Cam specs?
I will have specs and dyno in next 24hrs
I'm thinking of getting dynotune second option with speed,Inc ....
Any good tuners in chicago?
Old 05-29-2011, 12:45 PM
Streetk14
Streetk14's Avatar
Any ideas?
Is this an auto or manual? Either way, torque seems really low to me for a blower car. I was at 432 rwtq with a small'ish cam and LG headers on my '08 manual. With 10 psi from a T-trim and some meth, we got 578 rwtq and 683 rwhp. And that was with conservative A/F and timing. Charlie didn't want to be liable for pushing it any further with the stock pistons.
I'd think you should have at least 500 wtq, but who knows?
Old 05-29-2011, 08:16 PM
beavisr1
beavisr1's Avatar
More cubes!
Old 05-31-2011, 08:53 AM
APSGTO
APSGTO's Avatar
Originally Posted by beavisr1
More cubes!
Thats a bolt on right?
Old 05-31-2011, 10:04 AM
trapp
trapp's Avatar
[QUOTE=old motorhead;1577735922]Cam specs
Old 05-31-2011, 11:41 AM
Drewstein
Drewstein's Avatar
Looking at those specs I think the cam along with the low amount of boost is contributing to the issue. Either get a cam geared towards torque or go with a restricted setup.
Old 05-31-2011, 01:10 PM
TrenAman
TrenAman's Avatar
@8psi with a NA cam like yours I was at 640\522 with a P1.. you need a blower cam
Old 05-31-2011, 01:25 PM
trapp
trapp's Avatar
What the hell is a blower cam? I would expect the tuner to know. Remember I do alot of road/track events (not drag racing) ...I don't know if that makes any difference in selection...
To How to get more torque?
Old 05-31-2011, 01:29 PM
APSGTO
APSGTO's Avatar
A cam that is specifically designed for a blower(supercharger).
Your N/A cam may make great power N/A but under boost It may be bleeding off boost/compression hindering your blower from making the power it should.
Old 05-31-2011, 01:30 PM
TrenAman
TrenAman's Avatar
APSGTO summed it up at the sametime..
Old 05-31-2011, 01:37 PM
winters97gt
What specs do you all suggest on a blower cam?
Quick Reply: How to get more torque?
