1960 rear cross member is out, now....
Old 04-25-2011, 07:21 PM
thoyer
Support Corvetteforum!
thoyer's Avatar
Default 1960 rear cross member is out, now....
I got the rear cross member out. Pretty easy. Found a small area of rot in the frame above the cross member. Best method to fix?
I have two thoughts, one is to cut a peice of steel and insert it inside the frame rail, clamp and weld from the underside. Or cut peice of steel to cover area and weld directly over the hole, then grind smooth so the cross member sits flush.
Thoughts?
Looks like the mice lived here for a few years.....
Tom
Old 04-25-2011, 07:27 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
if the rest of the area around the hole is sound, then either way will work. but, if you decide to put the patch on the outside, make a similar piece for the other side so that the crossmember is even on both sides.
Bill
Old 04-26-2011, 12:13 PM
thoyer
thoyer's Avatar
Bill
Bill,
I'll have to as both sides have the same hole...............
Tom
Old 04-26-2011, 10:04 PM
Redbird
Redbird's Avatar
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
I would replace it with one from a vendor.
Old 04-26-2011, 11:10 PM
Pilot Dan
Pilot Dan's Avatar
That rusted from the inside out which means there are probably other thin areas as well. Since you went to the trouble of removing it, I would get a new replacement. For a few bucks more, it's worth it. Pilot Dan
Old 04-27-2011, 12:36 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
he's talking about the frame end, not the crossmember
Bill
Old 04-27-2011, 12:38 PM
thoyer
thoyer's Avatar
Bill
Correct. I have a new cross member that the original owner bought from GM back in the early 80's and never put in.
Tom
Old 04-27-2011, 04:13 PM
john5801
john5801's Avatar
Default cm
yep. i agree.. second---weld a "u' shape steel piece covering the 3 or 4 sides of the frame rail, and do the same on the other frame rail ..
( or if a box piece is available i would slide those on, and weld them..or fabricate one--2 ?)..
first--however, do the acid test would be to hit the frame rails with a ballpene hammer to see if you break through, then go from there with the boxing fabrication and welding...both sides...
thats what i would do...
hope this helps..
john
Old 04-28-2011, 10:26 AM
Pilot Dan
Pilot Dan's Avatar
Bill
OK, got it. For repairing the frame ends, I prefer to cut out the rotted area completely from the frame and fabricate and weld in new pieces in their place. Makes for a nicer finished repair that if done correctly and finish ground, will be hard to detect. How are you planning to install the new crossmember rivets??
Old 04-28-2011, 07:38 PM
thoyer
thoyer's Avatar
No rivets. Some grade 8 bolts and a bead across the front for now. If I ever go back to do a body off, then the rivets will go in. I hope to tackle it this weekend, we'll see.........
Tom
Old 04-28-2011, 08:38 PM
dharris45
dharris45's Avatar
I had the same problem with my 60. Ground out the rotted area and welded in patches on both sides. Sprayed some rust encapsulation paint on it the put on the new crossmember.
Old 04-28-2011, 08:58 PM
BobT59
BobT59's Avatar
I replaced the cross member in my 59 with a new one from ZIP last year.
Found the same issue with the frame part....I was not able to (and did not want to) do any welding on the frame. I cut a piece of steel, drilled some holes appropriately and slid in onto the inside of the frame and bolted the cross member into it. I did not use the rivets as in the original configuration.
I intend on putting a bead of weld across the front of the new crossmeber to the frame when I can...made a temporay brace in the meantime.
To 1960 rear cross member is out, now....
Quick Reply: 1960 rear cross member is out, now....
