1973 Tachometer Cable missing knurled nut
Old 03-13-2011, 02:14 PM
kdf1986
kdf1986's Avatar
Default 1973 Tachometer Cable missing knurled nut
Hello
I received my replacement tachometer cable for my 1973. It only has one knurled nut on the end to attach to the distributor drive gear. Shouldnt it have two bolts on it. One for the distributor, and one for the connection to the tachometer.
I dont want to start this job until I can confirm this. But I checked online with some of the vendors and the photos show two nuts.
I did buy it from a supporting vendor, so before I call their customer service I am checking that my assumption is correct before I request an exchange.
kdf
Old 03-13-2011, 02:16 PM
Gordonm
Gordonm's Avatar
The tach side is just a push on so no it should not have a nut. It is just a flared end that a clip on the tach holds the cable to it.
Old 03-13-2011, 02:23 PM
kdf1986
kdf1986's Avatar
Thank you Gordonm
I guess I will be crawling under the dash either today, or next week to replace this. The connection to the tach drive side broke because of the orientation of the distributor. I reclocked the distributor some time ago to remove the stress, but the cable was worn. I knew it would eventually go. Its not the gear drive inside, but the cable itself that broke.
kdf
To 1973 Tachometer Cable missing knurled nut
Quick Reply: 1973 Tachometer Cable missing knurled nut
