Rivet Nuts
Rivet Nuts
Plan to use some AL/AK series rivet nuts to attach items to the thin sheet metal or fiberglass engine compartment panels. Seems like a much better idea than self tapping screws.
Anybody have alternatives these products?
http://www.acfcom.com/product_profil...g%20Manual.pdf
Hi Dan, Rivnuts have been used in aircraft for as long as I can remember. The only issue is knowing the application. What are you installing? Most fasteners are application specific, so you should look closely at what load you have on it. I would hesitate putting anything heavy on a plastic panel though. Also, without the proper tools they can be hard to install.
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
They are stronger than sheet metal screws or pop rivets depending on which model you use. I've used them in production and like them.
Received 2,060 Likes
C6 of Year Finalist (performance mods) 2019
The biggest problem with blind fasteners other than the actual installation is having enough blind side surface area to avoid breakout or distortion of the parent material. Some applications are impossible, due to the limited strength of the parent structure.
