Old 02-19-2015, 07:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
removal of driver side mirror 1987 corvette
Old 12-23-2010, 01:58 PM
Ryancorvette
Ryancorvette's Avatar
Default removal of driver side mirror 1987 corvette
hello, does anyone know how to remove the driver side mirror? i already know that i need to take off the two bolts holding it on but im not sure about where it plugs in and how to get to it. pictures would help thanks!
Old 12-23-2010, 02:16 PM
jon0108
jon0108's Avatar
i would start by taking the door panel off and take a peak inside
Old 10-23-2012, 03:35 PM
mdsheley
8th Gear
mdsheley's Avatar
Default Driver side Mirror
I'm attempting the same thing. I don't know how to get to the two bolts either. I have isolated the connectors., but don't know how to replace it because I can't get to the bolts.
Old 10-25-2012, 12:25 AM
Enteringmidlife
Cruising
Enteringmidlife's Avatar
I will be watching this one, my mirror is cracked and needs replacement. While changing it out are there other viable options for the mirror for more viewing while maintaining the defrost option?
Old 10-25-2012, 12:37 AM
gerardvg
gerardvg's Avatar
With the door trim off you should be able to see the holes to fit a 3/8 socket extension thru perhaps 11 or 12 mm socket required a couple of inches down from the top of the door near the front.
You may need to shine a flashlight to see the bolts .
Old 10-25-2012, 02:38 AM
K87ZZ4
K87ZZ4's Avatar
It's been many years since I did this, but that's about what I recall, too. Two small holes in the metal door frame/panel that you can barely fit a socket through.
Old 10-26-2012, 07:48 AM
mdsheley
8th Gear
mdsheley's Avatar
I'll be replacing the mirrors this weekend and will have pictures to post. There are two small hold in door panel to push a socket up through.
Next question: How do you disentangle wiring harness from interior of door?
Thanks all,
Mike
Old 11-22-2012, 04:32 PM
Enteringmidlife
Cruising
Default Drivers side mirror
If you are wanting to work strictly on the side mirrors for either the motor or defrost mirror replacement, please do not waste your time removing the door panels to access the 2 bolts from within the door panel. Those 2 bolts are strictly for removing the side mirror housing.
I will post pictures as soon as I figure out how to, hopefully tonight.
P.S. dont have a URL to post to, thought I might try garage.
Old 11-22-2012, 05:00 PM
Enteringmidlife
Cruising
To remove the mirror/motor use a non marring bar and pry between the top of the mirror (there is a flat slot area) and the housing. This will allow the mirror to pop lose from the trunion between the motor and the mirror. Three screws hold the motor to a mount within the housing and the connector for the motor/defrost are self contained within the housing. Reassembly is just the opposite of removal.
Please insure that any pressure applied to the mirror face is in the center and not around the edge otherwise you will crack the mirror again.
Pictures are in my album, anyone wanting to help me understand how to insert the images, please speak up.
To removal of driver side mirror 1987 corvette
Quick Reply: removal of driver side mirror 1987 corvette
