C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Elite Engineering Catch Can Hose Connections
Old 11-20-2010, 02:46 PM
xcutter
CF Senior Member
Support Corvetteforum!
xcutter's Avatar
Default Elite Engineering Catch Can Hose Connections
I have searched the forum and haven't found a good set of install pictures for the Elite Engineering Catch Can on the LS7. My big question is how the hose connections go. From the top of the Catch Can to the engine, does this connection go to the top connector or the bottom connector on the LS7? I do not want to mix up the connections. Do the hoses line up (top of catch can to top connector on LS7)? Then the two bottoms to each other.
Old 11-20-2010, 03:20 PM
golf925
golf925's Avatar
top of elite engineering catch can hose to bottom connector on the ls7 and bottom hose on the catch can to upper connector (intake) on ls7
james,
Old 11-21-2010, 10:01 AM
xcutter
CF Senior Member
xcutter's Avatar
james,
Thanks
Old 11-21-2010, 12:08 PM
xcutter
CF Senior Member
xcutter's Avatar
Which person has their connections correct? It seems by searching on this forum, I can find people installing their Catch Can hoses both ways.
Top to Top
Top to Bottom
Old 11-21-2010, 12:15 PM
JohnnyLS7
JohnnyLS7's Avatar
Top to Top
Top to Bottom
didnt urs come with instructions... i have the same can and mine did and u can get it from the website... bottom line on the can goes to the top connection on your TB intake.
Old 11-21-2010, 12:17 PM
JohnnyLS7
JohnnyLS7's Avatar
Top to Top
Top to Bottom
the one you are saying is top to top is my install.. it just looks that way.... its not.... top of can goes to the bottom line on the car and the top line of the car goes to the bottom line in the can
Old 11-21-2010, 12:22 PM
JohnnyLS7
JohnnyLS7's Avatar
here you go... straight from the manufacturer
http://eliteengineeringusa.com/Insta..._Catch_Can.pdf
Old 11-21-2010, 12:32 PM
xcutter
CF Senior Member
xcutter's Avatar
Thanks alot. I looked for that pdf, but could not find it. It is very clear now.
Old 11-21-2010, 12:35 PM
JohnnyLS7
JohnnyLS7's Avatar
your welcome!!! post pics when ur done!
Old 11-21-2010, 01:24 PM
xcutter
CF Senior Member
xcutter's Avatar
Are you guys using the clamps that came with the can? It is easy enough to install them by the catch can connectors, but by the engine is got to be really tough.
Old 11-21-2010, 01:26 PM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Hi Rich,
Got your PM. Glad to see you've been linked to the correct instructions. Let me know if you have any more questions.
Paul
Old 11-21-2010, 01:27 PM
JohnnyLS7
JohnnyLS7's Avatar
no i didnt use the clamps... theres no need too plus from the factory theres no clamps.... push the hose on the barbed connectors and ull see its hard to pull off... it aint ever blowing off
Old 11-21-2010, 02:41 PM
xcutter
CF Senior Member
xcutter's Avatar
Here it is installed.
Old 11-21-2010, 05:43 PM
JohnnyLS7
JohnnyLS7's Avatar
sweet looks great!!!
Old 11-21-2010, 07:45 PM
craig04c5
craig04c5's Avatar
Good job Rich!
To Elite Engineering Catch Can Hose Connections
Quick Reply: [Z06] Elite Engineering Catch Can Hose Connections
