C5 vs C6 HUD - Comments
Acct suspended by request 21 Sept 2011
To GM: It's The Image Stupid
I do not dislike GM or C6s.
I acquired a C5 2001 vert in 2001, and have kept that vehicle. I acquired a 2011 C6 Z06 on Nov 6. Thus, I have a factual basis for my comparative comments here.
My C6 heads up display is no where near as good as the one on my C5. Yes, the new one has some good new functions: presents briefly with radio channel changes, and displays momentary navigational guide directions.
However, the size of the whole projected image on C6 is smaller than that of the C5, and the C6 projected image is much lower resolution than the C5 as evidenced by the slight but annoying pixelation. I am praying at this moment that some more knowledgeable soul will reply with a cure for both the small size and the pixelation: perhaps I remain ignorant of an available adjustment.
In the absence of such revelation, here is my GM scoreboard on that one aspect of my C6:
Points for conceiving and implementing heads up display in C5 Plus 10
Points for projecting ample proper size image on C5 Plus 10
Points for projecting a suitable image resolution on C5 Plus 10
Points for taking original brilliant masterfully implemented idea on C5 and diminishing the size of projected image on C6 Minus 10
Points for greatly reducing resolution of projected image on C6 Minus 10
Robert
Robert
Received 8,918 Likes
I believe the C6 HUD is much improved over the C5 HUD. I used both on the track and the C6 unit is more visible than the one on my C5Z. The track mode tach settings are better and the G meter is a nice feature that provides good feedback to the driver.
Bill
Bill
You can move the picture around, and it is possible to darken and lighten the image.
I think it's fine, and the new HUDs (all the way thru 2013 development cars) aren't much better.
The fact that GM is committed to OFFER the HUD in more and more cars is amazing on its own. Most cars don't have the option of a HUD.
(The funniest is the Camaro, it offers a HUD, something that less than 5% of all cars offer, while it doesn't offer a navigation system something which 80+% of cars offer. Go figure!)
Bill
The HUD in my c6 is fine as well.It's better then what was in my c5!Better visibility,track mode,better configuration.I guess it's subjective to personal taste and all that,but personally,I think you're wrong in your hypothesis!
The C6 HUD is way better. I still have and drive my C5 so I make the comparison every time I drive them.
The menu options on the C6 HUD are just CRAZY. They should be:
Tach: None/Linear/Round
G-Meter: On/Off
Gauge: None/Coolent Temp/Trans Oil Temp/Oil Pressure/Oil Temp
Street Mode:On/Off
The "Mode" Button would be used to cycle through the top level menu items (Tach, G-Meter, Gauge, Street, Quit) and the "Page" button to select the choices for each menu.
With this setup, you could customize the HUD to your likings. I like "Street" mode with the audio and navigation info, but I also like having the G-meter displayed. With the existing setup those two options are mutually exclusive.
Location: I speak the truth. Harsh but accurate. The Woodlands Texas
St. Jude Donor '09-'10
G-Meter: On/Off
Street Mode:On/Off
It took me a while to adjust to the C6Z display compared to my 04 C5 coupe.
Cruising
I would also have to agree. I own a c5 z06 and the actual image projected seems way clearer than that of a c6 (I've seen them both). I will agree that the c6 has better options but as far as clarity goes...it's night and day! C5 HUD FTW!
