problems with the cd player in my 1993
Old 04-02-2002, 10:57 PM
rubyredrdstr
2nd Gear
rubyredrdstr's Avatar
Default problems with the cd player in my 1993
my cd player was taking a disk in and just making a clicking noise,now it won't even take the disk????? any info would be helpful
Old 04-02-2002, 11:06 PM
khornet
khornet's Avatar
Location: Phx/but its a dry blast furnace kinda heat AZ
Default Re: problems with the cd player in my 1993 (rubyredrdstr)
Welcome to the world of Bose Gold! Probably expect to pay just under $200 to get it fixed. Here's some folks who do repairs.
http://www.carradio.com/ http://www.doctordons.homestead.com http://www.unitedradio.com/
or http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1341582136 http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1343581257
Old 04-03-2002, 12:02 AM
Mr Mojo
Elite Torch Red Member
Support Corvetteforum!
Mr Mojo's Avatar
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Same thing in my '93, but my '95 works perfect and has been used more. They must have made improvements, but since the '93 is race only, I'm not going to worry too much about it.
Old 04-03-2002, 12:06 AM
BAdAzZV8
BAdAzZV8's Avatar
Default Re: problems with the cd player in my 1993 (Mr Mojo)
Don't worry, mine doesn't like to play CD's anymore either. I just got a 12 disc player and called it good.
Old 04-03-2002, 12:25 AM
soundkillr
soundkillr's Avatar
Is it the bose gold? Mine did this, the logic unit gets confused because of bad resistors. I had to turn mine off, then put in the disk and turn it on. Then it would take it. I sent mine off to Dr. Don and had him repair it though, because nothing on the system worked correctly. Now it works as it should. Perhaps your logic IC is confused like mine was....
Old 04-03-2002, 09:21 AM
jsquared94
jsquared94's Avatar
i spent the other morning on the horn trying to get help with this problem. After speaking to some rebuilders, they say that it is a quite common problem, and it is the plastic gears inside the cd mechanism. It seems that over time they get out of alignment, causing it not to take cds, and also causing the laser not to line up with the cd correctly, therefore not reading a damn thing. It will accept or eject cds only when immediatly turned on, and will only make some wierd kind of "feedback noise", heard in the speakers when fiddling with the controls. No one will sell you parts to fix it yourself. They want to rebuild the whole damn thing for you! United Radio, in Syracuse NY, is cheapest, by the way at ~$185. Oh yeah, the head unit is manufactured by Panasonic (only the accoustics of the car are measured and engineered by bose, with the specs passed off). I called up Panasonic, and they MIGHT sell parts, but I'm not sure yet as they need a model first, and I havent yanked the unit yet.
And thats what I learned about the Bose Gold System. It took me over 4 hours and a call to Bose's corporate Japanese office.
JJ94
Old 04-03-2002, 10:19 AM
Kevin McGrade
Kevin McGrade's Avatar
Default Re: problems with the cd player in my 1993 (jsquared94)
Mine does the same thing when it is cold
Old 04-03-2002, 10:47 AM
Dragon2U
Dragon2U's Avatar
If you get the Panasonic part numbers for the repair could you please post it? I often tear into things and repair myself, especially when I can save a few dollars. In fact, this weekend I tore apart the passenger power seat gear unit and repaired it for $5 versus the $200 rebuild price ;) It should last at least another 8 years now.
I guess all those toasters and radios I took apart as a kid is paying off, lol.
Thanks :seeya
Old 04-03-2002, 11:59 AM
Ruby6spd
Ruby6spd's Avatar
Default Re: problems with the cd player in my 1993 (Kevin McGrade)
Ditto for mine, not a big problem cause I don't use the car in the winter at all
Old 04-03-2002, 02:20 PM
James94LT1
James94LT1's Avatar
Default Re: problems with the cd player in my 1993 (Ruby6spd)
This must happen to us all. Mine has done this for 2 years now. When the car has been sitting outside in like 100 degree heat it will work ok, weird! I thought maybe it was my fault for never cleaning the lens. I think I am going to get a disc changer if its close to $200 bucks to fix it.
James94LT1
Old 04-04-2002, 01:52 PM
behnevette
behnevette's Avatar
Another good place to send it is http://www.carstereohelp.com/
Very reasonable, has excellent "How-to-remove" directions on the website.
I had problems with the CD and the cassette and he fixed them both.
Old 04-04-2002, 04:09 PM
Goody
Goody's Avatar
Default Re: problems with the cd player in my 1993 (behnevette)
Had the same issues as you all. Took out head unit and replaced it with my Sony MDX unit. I like my mini's. :seeya
Old 04-05-2002, 12:22 AM
red-y
red-y's Avatar
My Bose is in the garage with some of my putters that also do not work. :yesnod:
Old 07-23-2014, 05:27 PM
CORVETTEV8
Cruising
CORVETTEV8's Avatar
Default Panasonic parts for cd player
Originally Posted by Dragon2U
If you get the Panasonic part numbers for the repair could you please post it? I often tear into things and repair myself, especially when I can save a few dollars. In fact, this weekend I tore apart the passenger power seat gear unit and repaired it for $5 versus the $200 rebuild price It should last at least another 8 years now.
Thanks
The parts needed for Panasonic Cd player 1993-1996 is sold here.
Ref : YESFD13002/e13002/13002 tête laser
http://fr.aliexpress.com/wholesale?S...D13002&catId=0
That's what DoctorDon and others do.
Consider 3h to do the job.
Old 09-18-2014, 06:54 PM
Stellabarbara
Stellabarbara
Stellabarbara's Avatar
2015 C4 of Year Finalist
Default CD not working
Mine too!, but I have a 1990. I believe it is the same radio as yours...
Old 09-19-2014, 03:14 AM
CORVETTEV8
Cruising
CORVETTEV8's Avatar
Default Cd laser
Probably. Nonetheless the problem is usually always the same. Dust in the optic lens or bad alignment with the disk.
If you have time to burn, you can try to clean it and to play with the 2 adjusting screws to find the correct perpendicular position of the laser diode. As for me I changed the optic tray for $ 36, and it works fine now.
Follow the link
Old 07-05-2019, 07:57 PM
jrobin1
jrobin1's Avatar
Where did you find the parts to repair your power seat track?
To problems with the cd player in my 1993
Quick Reply: problems with the cd player in my 1993
