Rocking Seat Solution: The Permanent fix
Old 06-19-2011, 11:19 AM
  #41
F&Yb0dluvr
F&Yb0dluvr's Avatar
I'm attempting to fix my rocking drivers seat today.
Old 06-19-2011, 11:48 AM
  #42
tonyb47
tonyb47's Avatar
I purhased a set of washers and did my drivers seat first, good instructions, but if you have sport seats do not pry off the up and down and forward seat adjuster as in the picture. Also the old washers were competely gone, disenegrated, seat is now tight, no more movement
Old 06-19-2011, 09:45 PM
  #43
K9Leader
K9Leader's Avatar
Okay, so the new washers didn't fix my rocking seat. It appears that one of the tracks is loose at the pivot points so I'm just going to have to live with it. It appears that my preferred seating position - steeply raked seat cushion, all the way down in the back, all the way up in the front - exacerbates the rocking. Other settings with the front lower do not rock as much.
Oh, and my favorite at the show this afternoon was this '62 in Sateen Silver with Red interior:
Old 07-11-2011, 02:36 PM
  #44
car48nut
car48nut's Avatar
Default spacers
Do you still have them for sale? I sure need a set. Thanks
Old 08-25-2011, 07:37 AM
  #45
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Spacers are back in stock and ready to ship.
Currently NOT accepting Paypal since they have decided to screw with my account for no apparent reason. Payments accepted by check/money order via mail only for the time being.
Old 09-13-2011, 03:27 PM
  #46
MTsVette
MTsVette's Avatar
Location: O'Fallon Illinois - Currently own a 2016 Z06 1LZ A8 Coupe
I fixed my "rocking seats" two weekends ago. I picked up the 8 nylon spacers at ACE for $2.64. The whole job (2 seats) took me under 3 hours! Seat tracks are like new now...no more rocking!!
Mike
Old 09-13-2011, 04:04 PM
  #47
Phace
Phace's Avatar
Mike
Did you get a part number from ACE for those? It would be nice to pick them up before attempting this job...
Old 09-21-2011, 06:26 PM
  #48
speedingbullets83
3rd Gear
speedingbullets83's Avatar
ive been trying to get the t40 bolts undone for the last 2days with no luck i dont see how you can get any kind of wrench on it
Old 09-21-2011, 06:36 PM
  #49
alankb
alankb's Avatar
Default wrench
Use one of those bits that comes with a scredriver with assorted bits. Put a GOOD 1/4 inch wrench on it and you'll get it.
Old 09-21-2011, 10:51 PM
  #50
TheRadioFlyer
Supporting Vendor
You can also use a 1-foot long extension of pipe as extra leverage. A little PB blaster might also help.
.....if all else fails, crank down with a set of large vice grips.
Old 09-22-2011, 02:00 AM
  #51
MTsVette
MTsVette's Avatar
Phace,
Here's the info:
Parts Required: 8 Nylon Washers total. 3/4" OD, 7/16" ID, 1/8" THICK. ACE Hardware for $0.33 each. The ACE part number for these washers is 59558K.
Good luck!
Mike
Old 09-22-2011, 02:03 AM
  #52
MTsVette
MTsVette's Avatar
I used vise grips on mine...came loose pretty easy...good luck!
Mike
Old 09-22-2011, 09:04 AM
  #53
TheRadioFlyer
Supporting Vendor
Phace,
Here's the info:
Good luck!
Mike
While you CAN use standard nylon washers, the 1/8" is too thick. They will need to be sanded down by hand since the required thickness is not commonly available.
For the record, sanding 4-8 tiny pieces of nylon by hand is not the easiest or enjoyable thing to do.
Old 09-22-2011, 09:25 AM
  #54
2slicks1vette
2slicks1vette's Avatar
Mike
$2.64.... Gotta love this forum
Did you have to sand them down?
Old 09-22-2011, 11:37 AM
  #55
Redeasysport
Redeasysport's Avatar
St. Jude Donor '05-'06
All you need is a pair of Channel Locks no one will see if you put a mark on the screw cap.
Old 09-22-2011, 11:39 AM
  #56
Redeasysport
Phace,
Here's the info:
Good luck!
Mike
Etiquette says when a vendor starts a thread a newb does not come in and suggest a different fix. Just sayin'......
Old 09-22-2011, 11:42 AM
  #57
alankb
alankb's Avatar
Default yes it is a pain
Literally, it hurts when you sand your fingers!
After all the work for this fix, my seat still has movement up and down. It looks like I need to weld one of the joints. Oh well, it is a hobby I guess!
To Rocking Seat Solution: The Permanent fix
Old 09-22-2011, 11:44 AM
  #58
2slicks1vette
Stop whining... Just sayin'
Old 09-22-2011, 01:22 PM
  #59
Gideon's_Test
Gideon's_Test's Avatar
Theradioflyer has been a great asset to this forum in numerous ways, from DIY's to unique parts, so while I found the Ace part number info helpful (I may decide to make my own) it is in poor taste to post in his thread about how do it without buying his parts.
Old 09-22-2011, 01:35 PM
  #60
Phace
Phace's Avatar
Do your spacers have the notch or edge cut as well as per the instructions so that the mechanism doesn't catch? I understand your spacers are filed to be the correct width, but how about that circumference?
Quick Reply: Rocking Seat Solution: The Permanent fix
