High HP 6 qt oil pan
Old 09-08-2010, 10:21 PM
65specialk
65specialk's Avatar
Default High HP 6 qt oil pan
Have found one. The drain plug is on the side of it. Is it a Corvette part?? Dave
Old 09-08-2010, 10:28 PM
Glasshole
Glasshole's Avatar
My 63' 360hp 6qt pan has the plug on the bottom......
Old 09-08-2010, 10:51 PM
RoadKing96
RoadKing96's Avatar
Location: Holly Springs, Nort Cackalacky / Jupiter, Florida
My 64' 365hp 6qt pan has the plug on the bottom as well......
RK
Old 09-08-2010, 11:14 PM
stingrayl76
stingrayl76's Avatar
It may be a Corvette part from who knows what year but it's not correct for a midyear. The drain for both capacities of midyear oil pans exits at the rear.
Old 09-08-2010, 11:17 PM
vintagecorvette
vintagecorvette's Avatar
The plug for a 6 qt pan should be on the rear edge of the pan, not on the bottom. This is a correct one.
http://cgi.ebay.com/ebaymotors/1963-...item27aac1a0a5
oWEN
Old 09-08-2010, 11:23 PM
RoadKing96
RoadKing96's Avatar
When I said bottom, I meant where it's relationship is to where found vs. the 'side'. I still consider this position to be the 'bottom' albeit the very end....
Sorry if it made this confusin....
RK
oWEN
Old 09-09-2010, 07:58 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
mine is in the bottom rear edge, facing rearward
Bill
Old 09-09-2010, 01:16 PM
65 vette dude
65 vette dude's Avatar
That's a repro pan......probably made in China. They are quite common on ebay.
Old 09-09-2010, 02:42 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
what is?
Bill
Old 09-09-2010, 02:44 PM
larrywalk
larrywalk's Avatar
The pan shown in post #5 on eBay appears correct, however, that pan requires a flat windage tray. The curved windage tray is used with the L82 4 quart pan.
Old 09-09-2010, 08:17 PM
65 vette dude
Originally Posted by wmf62
what is?
Bill
My bad.....of course I was talking about the pan with the drain on the side, that the OP was referring to.
Old 09-09-2010, 09:02 PM
65specialk
65specialk's Avatar
Default Oil pan ID
Looking from the front gasket surface the drain plug is on the lower right side. Directly below the bulge for the dipstick tube.
Dave
Old 09-09-2010, 11:04 PM
DZAUTO
DZAUTO's Avatar
Received 3,772 Likes on 1,674 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
oWEN
Jesus Christ Almighty, $699!!!!!!!!!!!!! Are they really going for that much now? And I thought they were outrageous back when I bought them from Chevy for about $50! I still have one in the attic, one curved and 2 flat windage trays. What the heck are the trays worth now?
Oh ya, the curved trays will fit ANY SB pan. I have one on the SB400 in the boat with a 57-62 style trap door pan and one on the SB400 in the Chevelle with a stock 4qt Chevelle pan (which has a flat bottom to clear the Chevelle front cross member).
Tom Parsons
Tom Parsons
Old 09-10-2010, 10:42 AM
larrywalk
larrywalk's Avatar
Tom, I wouldn't say that the curved trays will fit "ANY SB pan"...
Although I've used the curved windage tray (pm 3927136) with the 6-quart SHP oil pan (pn 359942) as pictured in the eBay link in post #5 on two different occasions, HOWEVER, it did not fit without interference - this interference required some bending of the baffle structure to work with the curved windage tray. On the other hand, this same 6-quart SHP oil pan DOES work without modification with the flat windage tray as used on the 1965 SHP small block Corvette 327s.
Old 12-04-2010, 08:30 AM
DZAUTO
DZAUTO's Avatar
Larry,
And you are correct. I probably should have mentioned that a SLIGHT adjustment is required. The specific reason that I used the curved tray in a pan on a SB400 is because the flat pan WILL NOT work with a SB400. NO WAY, NO HOW!!! That counterweights of that long 400 crank hit the flat tray, thus, I use the curved tray on SB400s.
Tom Parsons
To High HP 6 qt oil pan
Quick Reply: High HP 6 qt oil pan
