C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] ZR1 side skirt install
Old 10-25-2011, 08:26 PM
BIOHAZARDCYCLES
BIOHAZARDCYCLES's Avatar
Originally Posted by magicmanred
do yourself a favor and rivet the side skirts on. you need 4 rivets to attach the fender pieces to the side skirt anyway. it does a much better job and holds it much tighter to the car. and to drill them out incase you need to remove them is not a problem. another option is to go to GMpartshouse.com and buy the factory mudflaps. they are better quality and come with all screws and rivets needed for mudflap and sideskirts.
font mudflaps? do you have a part number?
also what size rivets and drill bit?
Old 10-25-2011, 08:32 PM
BIOHAZARDCYCLES
is it part number 8 here
Old 10-25-2011, 09:15 PM
Hirohawa
Hirohawa's Avatar
Do you use 3/16 rivets for every hole or just for securing the mudflaps?
Old 10-26-2011, 10:05 AM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by BIOHAZARDCYCLES
thanks..
what size rivets are you using and what size drill bit ? thnx
There are two factory screws at the front that are re-used. The side is held on with a long grip, wide head 3/16" rivet. 3/16" drill bit is used.
Old 10-27-2011, 08:25 PM
magicmanred
Cruising
magicmanred's Avatar
Default rear mud flap
why would you buy the front one. if you have a z or gs you have the front mudflap. you want the rear mudflap from a zr1. CALL (484) 949-2099. tell them you want {Hardware and splash guard kit} - $216.56 (for both sides)
that is gmpartshouse.com. it is genuine GM parts. it will have everything you need for the side skirt install and you will be much happier with there mud flaps instead of RPI's. good luck
Quick Reply: [Z06] ZR1 side skirt install
