Door Ajar Switch
Old 07-24-2010, 04:33 PM
IU-Z07
IU-Z07's Avatar
Default Door Ajar Switch
Whenever it gets hot out, the LH door ajar switch stops working properly. I have to wiggle it around to get the radio to turn off. How can I clean it or otherwise make it function properly?
Old 07-25-2010, 06:15 PM
94vettelover2
94vettelover2's Avatar
These door ajar switches are a poor design.I replaced both of mine & they still work poorly or occasionallyWhen they don't work my pass-key/alarm does not work & does not lock my doors
Old 07-25-2010, 08:20 PM
tblt44
tblt44's Avatar
I bought one from the dealer 30 bucks and it stuck,took it back and used a hacksaw on mine on both sides ,split it apart and cleaned it with brake cleaner than JB welded it back together.this was about 10 months ago and still working good.I only did this because i need one and didn't want to wait.
Old 07-26-2010, 01:14 PM
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Typically, the nipple/plunger device on the end of the switch is what goes bad. I replaced mine with a new switch from the dealer and it cured my problem. The switch on the passenger side was faulty, causing my alarm to go off after the ignition was off and the car was parked.
Old 07-27-2010, 11:33 PM
bub
bub's Avatar
Sprayed my '85's with WD40 and seems to have relieved the stickiness (for now).
Use the spray "snorkel tube", let soak for several minutes, then work the switch in and out several times by hand.
-CKB
Old 07-27-2010, 11:58 PM
IU-Z07
IU-Z07's Avatar
I was planning to try either WD40 or electrical connection cleaner. I didn't know if they would be damaging or helpful.
Old 07-27-2010, 11:59 PM
pmihaltian
Slingshot
Support Corvetteforum!
pmihaltian's Avatar
Replaced mine with these a couple of years back & they have worked fine ever since.
http://www.ecklers.com/corvette-door...1985-1987.html
Old 07-28-2010, 12:04 AM
OldCorvetteFan
OldCorvetteFan's Avatar
I bought a pair that look like that, but the ones on my '95 are flush at the end. Those tips don't seem to have any adjustment, and I believe that when the door is shut those little tips will be completely gone.
Anyone else run into this?
Steven
Old 07-28-2010, 01:02 AM
Eakster
Eakster's Avatar
My driver's side started to go. I spray some silicon lubricant in there and whack it in and out a few times- sorts it out. If it gets worse I will swap it with the passenger side one as obviously it gets much less use
Old 07-28-2010, 02:38 AM
vette079
vette079's Avatar
Steven
Look real close to the tip, you should be able to get in a small putty knife (back side) or the smallest screwdriver you can find and pry the tip out.
Old 07-28-2010, 06:50 AM
OldCorvetteFan
I didn't even think about that! Thanks!
Steven
Old 07-28-2010, 07:37 AM
vette079
vette079's Avatar
You can try with WD40, but it probably is a temporary fix.
Better of buying a new one or try to pry out the tip as mentioned in the prev. reply to "oldcorvettefan".
Old 07-28-2010, 09:54 AM
IU-Z07
IU-Z07's Avatar
What exactly is my goal when I am "prying out the tip?"
Old 07-28-2010, 02:52 PM
vette079
vette079's Avatar
If the internals of the switch are still OK.
Pry/pull out the tip for lets say 4 mm or 1/6th of an inch, and spray just a little WD 40 on the larger "****" where the pin sits in, because that is the actual switch.
It´s plastic in plastic and wears over time and will not slide in and out that easy.
Now you have pre/adjusted the switch, when you close the door now, the small pin is the first thing that hits the door post, thereby pushing in the switch enough so the electronic circuit in the switch closes.
When you open the door again, you will notice that the pin is pushed in in the larger **** again.
Now it is adjusted as it should be, the reason for this is that weatherstrips wear out and get thinner over time.
If you had a solid switch with no "adjustable" pin, you will end up with a switch that doesn´t close after a while.
In short you could call this small pin an adjuster pin.
If you did this and the radio still doesn´t switch off after you release the ignition key followed by opening the door, then the switch´s internals are most likely shot, wich isn´t repairable.
Only thing to do is to buy a new one, they aren´t that expensive and are not that hard to replace either.
Old 07-28-2010, 10:42 PM
OldCorvetteFan
So, if I'm reading this correctly, I install the new switch with the little pin completely extended - just as the picture above shows. When the door is closed, that head and pin assembly will be pushed into the body of the switch, thereby causing the switch to automatically and properly adjust itself.
I just kept looking at the new part, the old part, and visualizing my new part breaking the first time I closed the door.
Thanks!
Steven
Old 07-29-2010, 04:41 AM
vette079
vette079's Avatar
Pretty much, yes.
Before you close the door with the new part, be sure the wider **** moves freely in the switch, and see to it that the small pin only sticks out about 4 millimeters or so.
Be sure you have one for a 1994 model, the one back in post 4 (onedef92).
How are your weatherstrips?
Did you replace them recently?
In that case the plunger/small pin doesn´t push in that far compared to old strips, because they (new strips) are a little thicker.
Old 07-30-2010, 07:47 PM
IU-Z07
IU-Z07's Avatar
Thanks for the great instructions. The jury is still out on how well it worked.
What is the procedure for replacing the switch? Do I need to remove the door cover?
To Door Ajar Switch
Old 07-30-2010, 08:15 PM
bub
bub's Avatar
Yes...at least you do on an '85...in order to re-position the metal plate behind the fiberglass that the visible screws go into as well as undo the single pair wire connector.
Old 07-31-2010, 03:19 AM
vette079
vette079's Avatar
It´s just that the OP has a 90-96 model, so with a little luck he doesn´t have to do that.
There is a retainer on the inside of the door, that one you don´t want to loose track of, this is from the FSM:
Remove or disconnect,
1. Negative batt. cable
2. Lower screw. Replace with longer screw (Gm p/n 11503397 or equivalent started into retainer.
3. Upper screw.
4. Pull switch outward and rotate switch to expose upper screw hole.
5. Reinstall upper screw to hold retainer.
6. Remove lower screw.
7. Pull switch outward and depress harness lock tab to allow passage of switch and harness through opening.
8. Switch from harness.
Install or Connect,
1. Switch to harness.
2. Switch and harness into door.
3. Long screw through switch and lower door screw hole into retainer.
4. Remove upper screw.
5. Rotate switch and install upper screw through switch into retainer.
6. Remove longer screw.
7. Install original lower screw.
Done.
Old 08-02-2010, 09:53 PM
IU-Z07
IU-Z07's Avatar
Seems to be working! Thanks for the help.
Quick Reply: Door Ajar Switch
