Adhesive for "Stingray" Emblem
Old 05-26-2010, 12:49 PM
TopGunn
TopGunn's Avatar
Default Adhesive for "Stingray" Emblem
I removed all my stuff before painting, does anyone know what adhesive works best to reinstall the Stingray script emblem? Looks like whatever it is I'll have to apply it and trim it with an exacto blade.
Old 05-26-2010, 01:42 PM
SteveG75
SteveG75's Avatar
I removed mine for painting and never bothered to reinstall with adhesive. Mine are just held on by the pressfit of the three pins. Over 6 years with no issues. Makes it very easy to wax and clean the car since I just pull the emblems off and then push them back on. Over 6 years with no issues.
Old 05-26-2010, 03:10 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi TG,
I believe there's access to at least a couple of the 'pins' on the script on each side of the body so I'd think 'speed-nuts' would secure the script in place.
Have you considered that method?
Regards,
Alan
Old 05-26-2010, 03:11 PM
Lon Wayne
Lon Wayne's Avatar
Default Vader Vette
Six years no problem great for you. (I live in Ohio our roads are junk)"I would not do this" as the original stingray emblem would be trash once it hits the pavement.
3m ( Na Na Na Napa) makes an emblem glue I would use it.And yep you gotta be careful how much you put on.
Old 05-26-2010, 03:53 PM
gbvette62
gbvette62's Avatar
Received 2,017 Likes on 1,309 Posts
How you install them depends on what year you have and if they are original emblems.
69-73 "Stingray" emblems had 4 long studs, that take speednuts. 74-76 Stingray emblems had 3 short studs that were just there to properly position the emblem, they were installed using double sided tape. The 74-76 studs are to short to accept speednuts.
The 74-76 style emblems are the only ones that have been available from GM for the last 20 years. Correct 69-73s are available as a repro.
If you have 69-73 emblems, they can be re-installed using speednuts. If you want to install then using the double sided "automotive trim tape", you can get it at any auto parts store. This is the same tape that the automakers use to install emblems and moldings on new cars, and body shops use it too. It won't come off unless you want it to. It's a bit of a pain, triming it with an X-Acto knife, but it can be done.
Old 05-26-2010, 04:31 PM
0Virginia Vettes
Former Vendor
Virginia Vettes's Avatar
3M Emblem Adhesive is $5/tube. Be careful not to uses to much.
Virginia Vettes
Old 05-26-2010, 04:38 PM
SteveG75
SteveG75's Avatar
NJ roads, CT roads, RI roads, MA roads.
There is really no force on the emblems.
If you are paranoid, you a little bit of the 3M adhesive buit I would not slather the whole thing.
Old 05-26-2010, 04:48 PM
Frogday
Frogday's Avatar
I don't have the judging guide here, but I don't think there were speed nuts on any of the Stingray emblems...pretty sure they were all held on with pressure sensitive adhesive backing.
Old 05-26-2010, 05:08 PM
Alan 71
Alan 71's Avatar
Hi FD,
I looked... you're right...no nuts for 69-72 cars.
Regards,
Alan
Old 05-26-2010, 05:39 PM
Faster Rat
Faster Rat's Avatar
Ahh...nuts. I know they are not supposed to be there, but I used them anyway. Tried to apply and trim double face tape but it looked like crap. I'll leave it for the next caretaker to worry about, rather than me worrying about the original scripts falling off somewhere.
Old 05-26-2010, 06:33 PM
gbvette62
gbvette62's Avatar
I should have said that "69-73 Stingray emblems had 4 long studs, that WILL take speednuts".
69s may have used speednuts though, the 69 asembly manual calls for them. The aim shows the nuts in the installation illustration for the emblems and includes a part number for the them. 70 and later aims do not show the nuts in the illustration. 70-76 were held on with the tape backing, but I'm not sure about 69s.
Chevrolet may have intended to install them with speednuts or initially did, and found that because of the difficulty in accessing the back of them, they needed a different way to attach them. The studs on the 69-73 emblem are clearly long enough and sized properly to accept speednuts, and the studs are spaced to evenly hold the emblem to the fender.
Old 05-26-2010, 07:48 PM
TopGunn
TopGunn's Avatar
Originally Posted by Alan 71
Hi TG,
Regards,
Alan
Hi Alan,
Yes but these are the 74-76 versions I guess that have the short stubby pins just for positioning. They hardley stick thru but 1/8 after they penetrate the body.
Old 05-26-2010, 07:55 PM
TopGunn
TopGunn's Avatar
Yup these are the short stubby 74-76 ones. There was black double sided tape holding them when I took them off, it was sure cut nice to match the letters. I'll give it a shot with a sharp exacto knife and see how I do I guess. Hope I can get it in black
If that fails I'll try the 3M Emblem adhesive. I didn't know there was such a thing.
Thanks for all the replies and tips
Old 05-26-2010, 08:42 PM
OzzyC4
OzzyC4's Avatar
Virginia Vettes
and good advice aobut using just a little bit, less than you think is a little bit!
Old 05-27-2010, 07:03 AM
TopGunn
TopGunn's Avatar
Thanks Ozzy!
I don't have the car back yet, should be a couple of weeks. I cleaned these things up, removed the old faded black highlight paint and reapplied it with an artist brush under a magnifying glass. Came out looking pretty nice.
To Adhesive for "Stingray" Emblem
Quick Reply: Adhesive for "Stingray" Emblem
