Wiper Door-- electric conversion questions
Hi Gary, was reading your old post converting wiper door to electric actuator. I like your setup, it looks clean. Just wondering if you can help me and give me more details about this setup. I'm in the same process on my 71. part numbers for components you used, wiring details, where you installed your micro switch and any picture you can provide. appreciated
Any linear actuator with a 2" stroke will work. The one I used is no longer available. Get one with internal limit switches. Higher force linear actuators tend to be slower, preventing the wiper door from closing on the wiper arms.
I removed the scissor mechanism in the wiper bay and connected the actuator to the arm that comes off the cross shaft.
You replace the OEM limit switch with a dpdt microswitch (ebay). It mounts in the same place.
You can manually operate, making it simpler. I chose to use 2 relays to reverse polarity so it would work with my dash wiper switch.
List:
2" linear actuator
Diode
dpdt microswitch
2 relays
Couple pieces of metal for bracket
Switch
Schematic:
Pic showing actuator, dpdt limit switch/diode
List:
2" linear actuator
Diode
dpdt microswitch
2 relays
Switch
Schematic:
firgelliauto part #
I eliminated all but the main arm of the mechanism and used a 2" acuator.
http://www.firgelliauto.com/product_...roducts_id=136
It looks like they don't make that one any more. But any 2" stroke will work.
It requires very little force, but higher force actuators are generally slower. This allows the wipers to park before the door closes.
Garys 68 - is wiper door interlocked?
Is your wiper door interlocked to prevent the door closing on the wipers? it appears so, but you mentioned the linear actuator speed; therefore the question.
I looked at those linear actuators and it looks like their temp range is a high of ~150°F..... doesn't it get warmer than that in the engine compartment.
It is a beautiful setup you have going there though.
Unless you have a monster motor with little vacuum to use to run your headlight and wiper door why bother IMO. Just take some time to fix the vacuum circuit. It's pretty easy and everything is already there and no extra wiring, relays, actuators, brackets etc. to fabricate. Why is some so amendment that electrics are better than the vacuum system? Both have their ups and downs but to me the up side of the vacuum system is that:
1. It works
2. It's already all there
Not bashing you guys just wanted to voice my opinion.
1. It works
Got my idea straight from Garys68...
Untitled by Bill Smith, on Flickr
Haven't hooked up electric yet but battery on the actuator opens and closes great!
carriljc (10-28-2016)
wow.... great pictures
Are you using the same wiring setup that Garys-68 used?
#33
The ORIGINAL and bestest
Toronto Events Coordinator
I did a conversion that has both safety interlocks, and works exactly the same as the factory vacuum system. You can check it out here:
https://www.corvetteforum.com/forums...onversion.html
#34
The switch has 2 functions. It prevents the wipers from starting as in the original configuration. It also serves as a limit switch to stop the door from opening too far.
There's nothing there to prevent the door from closing before the wipers park, same as the original 68 design too...... I simply chose a linear actuator that was too slow to close before wipers come down.
carriljc (10-30-2016)
#35
I haven't wired mine yet so I'm not sure how it will end up. Since the wiper mechanicals seem to be haunted (pass side connecting rod flops around and I haven't found the problem yet) I'm on the fence whether or not to just go long hood.
