174 mph in a Convertible
Old 04-12-2010, 12:51 AM
  #61
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Originally Posted by LEAVINU
Wasnt at redline in 5th and being within 500' or so of the mark at that speed I didnt think about it fast enough to try.
I've always thought that top speed in a C6 or C6Z was reached in 5th gear. Dropping to 6th would actually slow the car down.
Looks like the ZR1 hits top speed in 6th...but it's got 638 crank HP and I've got about 500...and importantly, the ZR1 has a shorter 6th than we do, .67 vs ours at .57, that's a big difference.
I wonder if I had enough space if I'd be able to hit my current redline limited 191 top speed...or if I raised the rev limiter to 7200 my speed at redline 5th would be 199.9..... no way with my current power level.
That ZR1 is one fast car.
Joe_G is offline
Old 04-12-2010, 09:18 AM
  #62
LEAVINU
LEAVINU's Avatar
Thanks for posting Joe. This clears the air a lot I think. I knew something had to be up and it seems that this could be just what it is. I'll report back when I have time to hit the dyno for more in depth digging.
LEAVINU is offline
Old 04-18-2010, 09:48 AM
  #63
The Clevite Kid
Support Corvetteforum!
The Clevite Kid's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
My car would definitely bog down if I shifted from 5th to 6th at 180 mph.
The Clevite Kid is offline
Old 04-18-2010, 10:43 AM
  #64
TOBASCO
TOBASCO's Avatar
CI 2-4-5-6-7-8-10-11-12 Vet
NCM Ambassador
St. Jude Donor '08-'11-'13-'14-'15
There is a slight bogging down when going from 5th to 6th, mst likely due to the shift to a lower rpm, not to mention the wind resistance. You'll note that the ZR1 did the same thing during the Nurburgring record performance when it bogged a few mph before finally (barely) hitting 179 mph before having to brake. Cool video to watch though!
http://www.youtube.com/watch?v=OVAd5uTEyOU
TOBASCO is offline
Old 04-18-2010, 11:30 AM
  #65
Joe_G
Joe_G's Avatar
St. Jude Donor '08
With my gearing I'm at redline at 191 MPH...
And for sure you bog when going from 5th to 6th. Check out Steve in his C5Z which has a much lower 5th gear than our C6's. The C5Z tops out in 5th around 157.
I'm pretty sure GM put in a taller 5th in the C6 so that they could brag about the 186 top speed in the c6 and 198 in the C6Z...I still have the postcard somewhere.
Here's Steve, listen when he hits 6th.
Joe_G is offline
Old 04-13-2013, 06:36 AM
  #66
netacoma2003
netacoma2003's Avatar
I was running the original Goodyear tires with 11,000 miles on them, inflated to 38 psi cold, per the owners manual.
38psi? My 2009 has a tag in the door jamb stating I should inflate to only 30 psi. Am I missing something?
netacoma2003 is offline
Old 04-13-2013, 07:36 AM
  #67
Camaro4life18
Camaro4life18's Avatar
Congrats! You really got me thinking about the aerodynamics of a vert vs. a hard top. I've hit 170 bone stock in my '05 before I let off. She still had quite a bit more left in her, but I'm sure you are pushing my HP than I am stock. I would be really curious to see what the difference of the air turbulence is in a wind tunnel for verts vs. hard tops.
Camaro4life18 is offline
Old 04-13-2013, 07:38 AM
  #68
1bdvet
1bdvet's Avatar
Received 4,499 Likes on 3,586 Posts
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
1bdvet is offline
Old 04-13-2013, 08:58 AM
  #69
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
If the mile run is set up like a 1/4 mile run, the first set of lights is positioned 33 feet before the finish line and the second see of lights is positioned 33 feet after the finish line.
if you get off the gas at the time you cross the finish line, and start decelerating for that last 33 feet, vs staying in the gas for that last 3 feet, you can see why a GPS could show a higher speed then the average speed over 66 feet, if one is slowing down for the last 33 feet. Even if you stayed in the gas for that final 33 feet, and then you let off, your speed would be the average for the 66 feet between the lights where as the GPS would record the speed at the last timing light.
Or, whoever set up the lights, had them spaced incorrectly.
JoesC5 is offline
Old 04-13-2013, 09:02 AM
  #70
JoesC5
JoesC5's Avatar
Originally Posted by jsims002
I thought it was only necessary to hit 88mph.
Totally pulled off the "doc look" from back to the future
Seriously, 174 is pretty impressive, but running with stock Z06s = they are sissies or horrible on the right pedal
172-174 is typical for a stock Z06 in the mile.
JoesC5 is offline
Old 04-13-2013, 09:06 AM
  #71
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
Very nice run for one mile - that had to be on fun day.
Vetteman Jack is offline
Old 04-13-2013, 09:12 AM
  #72
MelAnn
MelAnn's Avatar
Default Yep!
Read the manual. 38 psi when driving over 175 mph.
MelAnn is offline
The Clevite Kid (05-01-2016)
Old 04-13-2013, 09:35 AM
  #73
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
http://forums.corvetteforum.com/foru...s-or-more.html
Vette_DD is offline
Quick Reply: 174 mph in a Convertible
