DIY Fix for the dreaded Falling HUD Display
Excellent write up!
Alas, I cannot complete as just my luck. THe plastic piece of the other side is broken too! So the mirror kinda moves around a bit. Dont want to install it like that only to have to redo it in the future.
Any known fixes. Can i at least buy a replacement piece? Part number anyone?
Thanks for any and all input.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Excellent write up!
BC
Excellent write up!
Here's some pics & descriptions of what I did:
Doug1 (11-16-2015)
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
You have to remove the dash pad. I can do the whole job in and out in less than three hours.
Navigator
Re: DIY fix for the dreaded falling HUD
Absolutely awesome post for this problem. Great pictures as well. I appreciate your time and effort. I will be pulling my dash pad and correcting my display next weekend. Thank you for your help!!!
Wondering if the screw threads will cut into the housing over time. It might be worth finding a plastic sleeve to go over the screw threads if there is enough clearance.
#33
Just fixed my HUD with the help of this thread. Took me 5 hours, first time removing anything on a Corvette. I forgot to cover the steering wheel with a towel or something so I scratched it a little bit while removing the dash. I was sad to see what I had done but with the HUD actually visible while driving, I quickly forgot.
Thanks!!!
Thanks!!!
#35
Navigator
Thanks for the HUD Repair info
I just completed the fix an hour ago and I have to tell you, I wouldn't have had any idea that I could have fixed the problem so easy without your post! I did the complete job in 5 hours and that wasn't getting in a hurry. I sincerely appreciate the article you wrote and the time you took to take pictures and showing the problem in such detail. I owe the same debt of gratitude to (at88mph) for his informative and detailed article on the disassembly of the console and dash. Anyone that hasn't tackled a project like this has no idea how informative and helpful both your articles are. Thanks to you my HUD is now working perfectly again!!!
#36
Fantastic!
Great post. I replaced my stereo yesterday and decided to tackle the HUD while I had the interior torn apart. Also took the opportunity to install silver trim rings around the gauges.
Very easy to do if you are at all mechanically inclined. The dash came apart very easily. Thanks to the repair instructions here, the HUD went back together just fine and now works great.
One thing I'd offer. When you reinstall the mirror, make sure that it moves freely through its range of motion. You can see the gear travel limit switches in the pics. The gear on the mirror mount has to be installed at the right place or it won't travel. If you can't move it by hand (easily) from one limit switch to the other, take out and try again, changing the gear position until you get it right.
Also, try everything out before you reinstall the dash to make sure it works.
Good luck!
Darryl
2004 Black/Black coupe
1974 Black/Black coupe
Good luck!
Darryl
#37
Good luck!
Darryl
Good luck!
Darryl
Followed the instructions to a T went outside reinstalled the HUD nothing. Came back read the quote above followed recommendation and it worked!! Thanks
#39
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats his forum Name also..
Bill Curlee
#40
Thank you for this post.
I followed it step by step and mine is completed. It took me a while because I am very limited in my mechanic experience, but I finished it and it works just like it is suppose to.
Thanks.
Thanks.
