Old 02-19-2015, 07:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
How do the C5 side mirrors come apart??
Old 07-22-2009, 03:55 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
Default How do the C5 side mirrors come apart??
www.vetteessentials.com get the door panels off, done that once or twice.
3 nuts retain the mirror, how does the mirror remove from the housing?
thanks
have some rock chips, thinking of having some paint work done on a set
Old 07-22-2009, 04:03 PM
feeder82
feeder82's Avatar
from my 2002 service manual after removal from the door,
1. Push in on one edge of the mirror glass tilting the mirror case to allow finger access
2. Grasp the glass case firmly and pull the case from the mirror body.
3. Disconnect the wire connectors from the case.(heated mirror)
Old 07-22-2009, 04:13 PM
jedblanks
jedblanks's Avatar
4. Replace the glass you just broke.
SteveDoten (08-11-2017)
Old 07-22-2009, 04:26 PM
SteveDoten
SteveDoten's Avatar
I want someone that is signed off on this task, I also have the shop manual
Old 07-22-2009, 04:53 PM
Tech
Tech's Avatar
Picture forthcoming...
Old 07-22-2009, 05:06 PM
Tech
Tech's Avatar
I happen to have a replacement mirror that I picked up from the dealer today. I cracked my passenger mirror reinstalling it. ~$85 GM list. When you reinstall, use the palm of your hand in the middle of the glass.
Old 07-22-2009, 05:24 PM
SteveDoten
SteveDoten's Avatar
damn!!!!!!!!
this is the info I need, how does it come apart?
thanks for the pics, never been in there before
Old 07-22-2009, 05:30 PM
Tech
Tech's Avatar
Like the service manual says, push in on the lower inside corner and gently pull. It feels as if you're going to break it... so be careful and don't get in a rush.
Oh.. btw... I'm not sure of there is a polarity difference in the electrical connectors, so I marked one of them with a Sharpie before disconnecting.
Old 07-22-2009, 09:09 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
So you press in the left bottom corner and pull mirror from the top right corner ?
Going to be installing some mirrors with turn signals in the mirrors soon.
Thanks.
Old 07-22-2009, 09:33 PM
byronhunter
byronhunter's Avatar
Thanks.
That works, I've done it. But, you better read the service manual before you try to reinstall it. Read it and understand it.
Old 07-22-2009, 09:34 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Any tips ?
Old 07-22-2009, 09:45 PM
Tech
Tech's Avatar
I just reinstalled mine... and had to apply waaaay more pressure than I expected. My arms were shaking I was pushing so hard. I suggest installing the glass with the mirror off the car... and being very patient with the first one. The second one will go faster.
As far as tips... there are two columns (better word is escaping me) that have a ball on one end and threaded internally. The power mirror rotates a threaded shaft inside these columns to adjust the mirror. When I pulled my mirrors off, those shafts stayed with the glass. I recommend leaving them on the glass. Line up the columns in the appropriate places in the mirror housing and use the palm of your hand to apply pressure behind the column (mirror side). Push in the bottom column (it'll click when it runs down the threaded shaft). Then push in the side column. Then center the glass in the housing, and apply firm pressure gradually in the center of the mirror using the palm of your hand. It's very important to keep the contact area big and centered. Ask me how I know.
I've installed side view mirror glass before... and these had my butthole puckered. (sorry for TMI )
Bwadd (03-20-2024)
Old 07-22-2009, 09:48 PM
Tech
Tech's Avatar
@Steve
If you're keeping the mirrors the same color, I suggest simply taping up the glass. I know you're handy with tools, but the risk is not worth the reward.
Old 07-22-2009, 09:55 PM
byronhunter
More tips from the Service Manual.
Mirror Face Replacement
Removal Procedure
Caution
When working with any type of glass or sheet metal with exposed or rough edges, wear approved safety glasses and gloves in order to reduce the chance of personal injury.
Push in on 1 edge of the mirror face glass tilting the mirror case to allow finger access.
Disconnect the wire connectors from the case (heated mirror).
Remove the 2 jackscrews from the mirror glass case.
Bend the jackscrew over.
Press down on the side of the jackscrew popping the jackscrew from the mirror glass case.
Save the jackscrews for reinstallation to the mirror motor.
Installation Procedure
Caution
IMPORTANT
The mirror glass case is not the same for the right and left mirror. For ease of assembly of the mirror glass case place a little white lithium grease on the motor pivot and on the tip of the installed jackscrews.
The jackscrew springs must be positioned down compressing the fingers at the bottom of the jackscrews. Push to install the jackscrews into the mirror motor.
Rotate both jackscrews to position the ball flanges to be inline with the attaching hub. They will then be correctly positioned to the mirror glass case. (This is shown in the above graphic).
Connect the electrical connectors to the mirror glass case (heated mirror).
Align the case to the mirror motor.
With the palm of your gloved hand press firmly on the center of the mirror glass case until the case engages onto the motor.
Push the mirror glass case to the jackscrews.
Right mirror. Rotate the mirror glass case down and press firmly on the lower side engaging the mirror glass case to the lower jackscrew.
Left mirror. Rotate the mirror glass case up and press firmly on the upper side engaging the mirror glass case to the upper jackscrew.
Rotate the mirror glass case and press firmly on the outer side engaging the mirror glass case to the outer jackscrew. The jackscrews will give a clicking noise when properly seated.
Raith (05-01-2020)
Old 07-22-2009, 09:56 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Thanks for the info, I have two I can practice on, before putting in the Muth units.
Old 07-22-2009, 09:58 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Thanks byronhunter, that saves me from looking up info.
Old 07-23-2009, 05:04 AM
Choreo
Choreo's Avatar
Here is what the inside looks like after the mirror is removed...
More info here...
http://forums.corvetteforum.com/c5-t...tor-packs.html
To How do the C5 side mirrors come apart??
Old 07-23-2009, 08:45 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Thanks Choreo,
Check out this link after reading yours, I found this. http://www.muthco.com/techsupport/pdfs/21001070.pdf
More info here...
Old 07-23-2009, 11:23 AM
jedblanks
jedblanks's Avatar
The problem is the mirror glass glued to this plastic frame is very thin and I assume it gets brittle from heat. Mine snapped in half using this very procedure. Luckily replacements can be had on ebay for about $20 shipped (glass only).
Old 07-23-2009, 11:39 AM
Mark C5
Mark C5's Avatar
St. Jude Donor '08-'09-'10
My drivers side mirror changes it's position every time I start the car and never to the same position twice. I've tried to remove the mirror per the service manual but the I'm not comfortable with the amount of pressure required. I'm pretty sure I'd have to break it to get it off so I'm just living with it.
Quick Reply: How do the C5 side mirrors come apart??
