spark plug wiring diagram
Old 07-12-2009, 01:56 PM
chub
chub's Avatar
Default spark plug wiring diagram
Does anyone have a diagram of the plug wiring diagram for a 66 327 350hp? I have a service manual but apparently I am blinder than a bat cause I can't find it.
Chub
Old 07-12-2009, 02:02 PM
62Jeff
Support Corvetteforum!
62Jeff's Avatar
What specifically are you in need of?
The clocking of the wires on the cap, the routing of the wires down to the oil pan and back up through the motor mounts to plugs 1, 2, 3, 4, the order in which the 4 wires are routed through the loom on each side?
Etc. We can help, once we know more about what you need
Old 07-12-2009, 02:08 PM
ml1955
ml1955's Avatar
http://www.classiccarauto.com/impala...istributor.png
Try this diagram, #1 plug on cap is after the window to adjust pints if I remember correctly... My '55 cap does not have the modern technology of those later caps
chub
chub's Avatar
jeff, I have a dead miss. The plugs are new so I thought that I could have a plug wire connected to the wrong plug in the firing order. I am going to trace the wires but I was looking for a pic of the wires on the distributor for firing order.
Chub
Old 07-12-2009, 02:12 PM
62Jeff
62Jeff's Avatar
Chub
Firing order is 1 8 4 3 6 5 7 2. Typically the #1 wire is between the points window and the vacuum advance.
Edit: Looks like ml1955 has it covered.
chub
chub's Avatar
thanks ml1955.
chub
Old 07-12-2009, 02:14 PM
chub
chub's Avatar
Thanks to both of you.
Chub
Old 07-12-2009, 03:05 PM
JohnZ
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
Here's a photo...
Old 07-12-2009, 04:14 PM
BarryK
BarryK's Avatar
Old 07-12-2009, 05:24 PM
magicv8
magicv8's Avatar
There are links to Corvette wiring diagrams in the help
section near the bottom of this web page
( http://home.mchsi.com/~magicv8/index.html )
that show the wiring sequence and routing.
Old 07-12-2009, 06:16 PM
chub
chub's Avatar
Thanks John z, barry and magic it helps a lot. Sorry it took so long to respond but I have been under the car.
Chub
Old 07-12-2009, 06:20 PM
Black_Magic
Black_Magic's Avatar
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
And another
George
Old 07-12-2009, 06:24 PM
chub
chub's Avatar
thanks black magic
To spark plug wiring diagram
Quick Reply: spark plug wiring diagram
