Best Street/Strip Cam for LT1 383
Old 06-02-2009, 10:28 AM
JimiHendrix
JimiHendrix's Avatar
Default Best Street/Strip Cam for LT1 383
Hi guys,
Im looking for an agressive street cam. Let me tell you a little about my build.
I have a 1996 Lt1 coupe. It has a completely forged bottom end, six inch rods, and SRP forged pistons. Compression will be 10.5 to 1 with a standard head gasket. Stall is 2400, with a beefed up tranny. I also have a 3:07 D-36 rear.
The heads........wwweeeellllll. . . . due to time and cost restrictions, I am reinstalling stockers which will have bowl work and a new valve job. I have the old heads out for porting (expected 260ish CFM at 550.), but wont have em back for at least a month and a half.
I am installing beehive springs (918's) now to handle any lift up to .600.
I need to install the cam to go with the later heads. I can handle any emissions issues. Also, I have shorty headers.
I was looking at the Gm847, the Comp XFI 280H , the Lunati 60122 and others. Any recommendations.
Old 06-02-2009, 10:42 AM
rickneworleansla
rickneworleansla's Avatar
Why not go with a custom cam. Tell them exactly what you are looking for. I chose LE. They have done tons of these setups and can get you exactly what you are looking for.
Old 06-02-2009, 10:53 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Those cams are a little big for a 3.07 gear
Old 06-02-2009, 11:05 AM
JimiHendrix
Any recommendations then?
Also, what if I go up to a 3000 stall torque converter?
Old 06-02-2009, 01:18 PM
92ZR1WANNABE
92ZR1WANNABE's Avatar
Here is a link to some pretty good cam selection information for the LT1.
http://www.ls1lt1.com/forum/showthread.php?t=25032
It should be able to answer most of the questions you have.
**Edit**
Come to think if it you should read the last 8 words in my sig, something tells me your going to be in the same boat.
Old 06-02-2009, 01:39 PM
96lt4c4
96lt4c4's Avatar
check my sig, car was capable of mid 11 seconds
Old 06-02-2009, 02:00 PM
biggrizzly
biggrizzly's Avatar
2015 C5 of Year Finalist
After you get your flow numbers back for the heads, talk to Lloyd or Brett Bauer and give them your car's specs and what you want and see what kind of cam those guys recomend. Simple as that.
To Best Street/Strip Cam for LT1 383
Quick Reply: Best Street/Strip Cam for LT1 383
