How do you remove this piece of the sun visor (pic)?
Old 01-23-2009, 08:47 PM
magnetized
magnetized's Avatar
St. Jude Donor '09
Default How do you remove this piece of the sun visor (pic)?
I'm swapping my old broken sun visors for some new pristine sunvisors and I can't get this bezel/clip off the old ones to swap over. Any help is appreciated
Old 01-23-2009, 10:43 PM
c5blkvetteguy
c5blkvetteguy's Avatar
That part stays on the end of the visor. Just undo the wire.
Old 01-24-2009, 12:29 PM
magnetized
magnetized's Avatar
St. Jude Donor '09
The sunvisors are removed, unclipped, etc. I need to swap the circled bezel off of the old sun visors.
Old 01-24-2009, 04:50 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,918 Likes on 5,327 Posts
Looking in the Service Manual its supposed to be easy. Here are the complete instructions for replacing the sunshade.
Sunshade Replacement
Removal Procedure
  1. Tilt the sunshade down toward the windshield.
  2. Insert a flat head screwdriver blade into the slot in the sunshade inner bezel.
  3. Using the screwdriver against the elbow of the sunshade arm for leverage pull down on the sunshade arm while rotating the sunshade outboard until the sunshade stops. (the first tab disengages).
  4. Push up on the sunshade and continue rotating the sunshade outboard until the sunshade with the inner bezel disengages from the mounting bezel.
  5. Disconnect the electrical connector.
  6. Remove the sunshade.
  7. Disassemble as necessary.
    • If removing the mounting bezel, pull the bezel from the garnish molding with your fingers.
    • If replacing the inner bezel, remove the bezel from the sunshade shaft and press the new bezel onto the shaft.
Installation Procedure
  1. Route the harness through the mounting bezel.
  2. Insert the mounting bezel into the garnish molding engaging the snap fingers.
  3. Connect the harness to the sunshade electrical connector.
  4. Push the connector up through the bezel and through the hole in the garnish molding.
  5. Position the sunshade approximately midway between the windshield and the side of the vehicle.
  6. Insert the rod with inner bezel firmly attached fully into the mounting bezel.
  7. Rotate the sunshade toward the centerline of the vehicle until the sunshade locks in place.
Like I said its supposed to be easy but there are no specific instructions on how to remove that bezel.
Bill
Old 01-24-2009, 06:00 PM
dougbfresh
dougbfresh's Avatar
The bezel came on the last one I ordered new. Not sure you even can remove it after assembly. Where did you get the visor(s) from?
Old 01-25-2009, 03:23 PM
magnetized
magnetized's Avatar
St. Jude Donor '09
Bill
That will help, thanks
I got them from a member, I'm going to pm them and see how they were able to get them off.
Old 01-26-2009, 09:55 AM
runamuk
runamuk's Avatar
Cruise-In V Veteran
St. Jude Donor '04
I also order some sun visors new from GMPartshouse.com and they came with the bezel attached.
Old 08-05-2010, 07:34 PM
Dukenukemx
Dukenukemx's Avatar
Anyone have the part # for the Sunshades? I wanna to get some new ones from GMpartsdirect.
Old 08-05-2010, 09:32 PM
FLYNAVY30
FLYNAVY30's Avatar
Received 2,363 Likes on 1,033 Posts
If you want mine, I can send them to you in a week or so...Im redoing my headliner and getting rid of the visors entirely because Im so tall, it improves my field of view, and I never use them anyway
Old 09-08-2010, 01:40 AM
arcticZ51
arcticZ51's Avatar
I'd like to remove mine as well but what do you do with the hole that's left behind? TIA
Old 10-26-2010, 11:27 AM
jbalas
1st Gear
jbalas's Avatar
Default Need Driver's Side Visor
Looking for a driver's side visor for a C-5 (2003). Anybody? FLYNAVY30?
Former Squid
jb
Old 11-05-2010, 12:56 PM
British
British's Avatar
Looks like a good writeup, I'm going to need to do this myself probably... My mirror popped off and it's just dangling... There doesn't seem to be a good way to glue it back on there.
Old 11-05-2010, 08:46 PM
Sting99
Sting99's Avatar
That bezel broke on my Driver's side visor. I did not see a part number? Is it replaceable or do you have to get a complete visor? I noticed that on the instructions it explains how to slide the visor thru the bezel?
Please advise
Old 12-09-2010, 08:47 PM
billyward
billyward's Avatar
Default 1998 corvette triangle locking devices
how can i find two of these triangle locks and bezzells?. my visors are like new but the triangles and bezzels are broke. some one tried to steal my visors and jerked them out of the ceiling breaking the locks and triangle devices. please answer!
Old 12-09-2010, 08:55 PM
billyward
billyward's Avatar
there is got be a way to get 1998 corvette visor locking devices.
Old 12-09-2010, 09:00 PM
billyward
billyward's Avatar
are those triangle locks called inter bezzells?
Old 12-09-2010, 09:20 PM
billyward
billyward's Avatar
Default inner bezel
i need a couple of those inner bezels you are trying to get off. where can i get them?
To How do you remove this piece of the sun visor (pic)?
Old 12-09-2010, 09:23 PM
billyward
billyward's Avatar
if any one knows how to find inner and outer bezels for a 1998 corvette visor please reply!
Old 02-24-2011, 09:33 PM
92GA
92GA's Avatar
Oldtimer
I just replace my visors with new ones I bought off of E-Bay. They were supposed to be gm, I don't know about that but they fit perfect. Just for the heck of it I removed the locking bezels. They were in a warm garage, but I just opened my vice a little, so not to hold tight, and taped the part where the wire come through and the bezel came right off. No damage.
Old 08-22-2012, 02:24 PM
shwtrkman
2nd Gear
shwtrkman's Avatar
Do you still have the visors? I thought the visors with lighted missors were stock but the C5 I just bought does not have them. I would also need the clips they attach to. One of mine is broken.
Quick Reply: How do you remove this piece of the sun visor (pic)?
