Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
**NEW PRODUCT** Blow Dry Your Car and Save Your finish
Old 09-22-2008, 07:58 PM
  #41
Pipedreams
Pipedreams's Avatar
St. Jude Donor '06-'07
Will be posting a video soon.
Old 11-24-2008, 09:08 AM
  #42
Pipedreams
Pipedreams's Avatar
Old 12-04-2008, 05:56 PM
  #43
Pipedreams
Pipedreams's Avatar
Old 12-05-2008, 05:45 AM
  #44
TOGWT
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
What is its suction lift? (inch water gauge ) (water lift sealed suction measurement).
Old 12-05-2008, 06:10 AM
  #45
Pipedreams
Pipedreams's Avatar
Its a blower
Old 12-05-2008, 10:11 PM
  #46
CodeBlack
CodeBlack's Avatar
How does it compare to an air compressor as far as pressure and is the hose long enough so that you don't have to hold the unit in your free hand. I'm accustom to using the compressor and a towel at the same time
Old 12-05-2008, 10:38 PM
  #47
Pipedreams
Pipedreams's Avatar
You can't dry you car with an air compressor, the hose is 10' and you can purchase a 10' extension. Take a look at the video.
Old 12-06-2008, 01:27 PM
  #48
CodeBlack
CodeBlack's Avatar
I looked at the video and saw water coming of the car the same way it comes off using an air compressor. I'm in no way knocking your product and would prefer purchasing your product VS having a 60 or 80 gallon 16cfm, air tank in my garage. If it works that good I can get a smaller compressor to work on my car and use your set up to dry the car. If it doesn't work better than the air compressor can I return it free of charge?
Old 12-06-2008, 02:01 PM
  #49
Pipedreams
Pipedreams's Avatar
Yes, blowing water out of a confined spot like the marker lights it may look the same as a good compressor. Problem is if you have a compressor that uses oil you should never use that on your car unless you have a great separator and the compressor air is not heated.
Second like I said, you no way can dry your entire car with an air compressor, I have tried. If you’re happy with your compressor and towels you might want to stick to that. The master blaster is in a completely different class then compressor and leaf blowers (both which have merit) I have close to 250 customers on the forum and all the feedback has been “better than expected”
You welcome to try it out, but as with any company shipping is not refundable (either way)
PS: just noticed you are on LI, I have a detailer friend in Commack, he is craigster05 on the forum and he shot the video, I am sure he would let you test it out.
Old 12-06-2008, 02:19 PM
  #50
CodeBlack
CodeBlack's Avatar
Thanks, what's the name of his store. I would like to do away with using a compressor
Old 12-06-2008, 03:22 PM
  #51
Pipedreams
Pipedreams's Avatar
I will have him contact you
Old 12-10-2008, 07:14 AM
  #52
Pipedreams
Pipedreams's Avatar
Old 12-17-2008, 09:11 AM
  #53
Pipedreams
Pipedreams's Avatar
Don't get stuck with the same old gifts, tell them this is what you want
Quick Reply: **NEW PRODUCT** Blow Dry Your Car and Save Your finish
