Why Is A C5 Fast Than A Trans Am
Old 06-20-2008, 02:30 PM
Mike Mercury
Mike Mercury's Avatar
Originally Posted by AU N EGL
how many TA have you weighed?
I have weighed five, not one use under 3650 the other four were 37xx lbs PLus driver. put them close to 3900 lbs
Vette and driver 3400 to 3450 lbs that is 500 in my book.
zing; bada bing !
Old 06-20-2008, 03:54 PM
OhioC5
OhioC5's Avatar
Originally Posted by casslaw
I can't believe I am replying to this, but... I had a '99 Camaro with only a lid and catback, It ran 12.0's all day, and it was a 6 speed. I beat many stock Vettes in that car, and when you are talking about a couple of tenths, a driver can make that up in a number of ways. Either car spinning a car length off the line makes the difference. Internet racing is just that, and I am sure that most of us have had experiences with F-bodies, mustangs, and even turbo'd benz's that would surprise you. The reason the Vette is faster stock is because it is a VETTE and Chevrolet wouldn't have it otherwise, but the second you get out of the stock realm, things change dramatically.
I cant believe Im replying to your reply that you can believe your replying too. So, you ran 12.00 with a factory Z-28? I would like to see that timeslip........
Old 06-20-2008, 04:38 PM
procs2v
procs2v's Avatar
To me a t/a is about equal. I've been 13.10@107mph all stock driving a friends car. 2nd pass in the car. With headers only, no tune, on stock tires I have been 12.79@110mph
Old 06-20-2008, 04:41 PM
99C5JA1
99C5JA1's Avatar
I don't know if you're replying specifically to my post, but I was trying to show as fair of an apples to apples comparison as I could. You can find timeslips posted in a million different places at different tracks and different elevations. This was the same day, same track, same basic mods with a good sampling of F-cars and a couple C5's. Of course factors like the driver, traction, and whatnot make a difference. But you can look at the averages with the exact same conditions and get a decent assessment of what the cars are going to do at the mostly stock level.
Old 06-20-2008, 06:15 PM
Zo Sex
Zo Sex's Avatar
no t/a runs a 12 flat all day long with just a lid, ok. yea and my 01 z came stock with 505hp!
Old 06-20-2008, 06:42 PM
casslaw
casslaw's Avatar
Um, that was supposed to be 13.0, and I swear I read it twice because i put 12.0 the first time.... My bad, and I'd like to see that time slip too
Old 06-20-2008, 06:57 PM
mvvette97
mvvette97's Avatar
St. Jude Donor '06-'07-'08-'09
I ran my vette at the track on test and tune day against my buddy. He had a 2002 Z28 with headers and a stall. I had headers also. We ran like 4 times and the outcome was the same on every run, nose to nose at the finish. So really I think they run about the same stock to stock. Now my ws6 is a little differant story..
Old 06-20-2008, 07:23 PM
OhioC5
OhioC5's Avatar
Thats kinda what I thought, your allowed a typo.
Old 06-20-2008, 08:10 PM
Mike94ZLT1
Mike94ZLT1's Avatar
Originally Posted by CL
They have a smaller cam profile and GM did not want to have the flagship car out done.
No, they do not. An LS1 is an LS1 is an LS1, year for year. The 500 lb weight difference, and the driver have ALOT to do with it. M6 cars or A4 cars?
Old 06-21-2008, 12:56 AM
Camjamsdad
Camjamsdad's Avatar
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I'm gonna go with gear ratio. Or do they have the same gears in the trannys and rear ends?
No jokes about trannys and rear ends.
Old 06-21-2008, 02:42 AM
mvvette97
mvvette97's Avatar
Somebody correct me if I'm wrong but automatic vette will have the 2.73 and the Z51 has the 3.15. The M6 vette has the 3.42. Auto F bodys are a 3.23 while the M6 is 3.42
Old 06-21-2008, 06:39 AM
danziger
danziger's Avatar
Heh. The "average" weight for a LS1 F-body is 3500 lbs when you look at both ends of the spectrum from "stripper" Z28/Formulas to loaded 'vert WS6s.
The early Vettes did indeed have a slightly different cam, but it was negligible at best. A LS1 is a LS1 is a LS1.
The Corvette has a slightly better exhaust, but that is offset by the IRS, so both cars will dyno the same, or with the Vette slightly lower.
M6 gearing is the same between the two, but A4 Vettes offered 2.73s or 3.15s, while A4 F-bodys had 2.73s or 3.23s.
As pointed out earlier, the main advantages the Vettes has is weight and aerodynamics. The weight will usually offset the IRS out of the hole and the aero will shine at the top of the track. This is why Corvettes may not always get a better time, but will usually have a higher trap.
The LS1 F-body may not be as much of a sports-car as a C5, but they are a cheap, reliable platform that can do many things well and are ridiculously easy/relatively inexpensive to make fast.
Old 06-21-2008, 11:09 AM
  #33
nj02vette
nj02vette's Avatar
Location: Marlton. Increasing performance one speeding ticket at a time! NJ
Originally Posted by Mike Mercury
zing; bada bing !
Not sure what your getting at here Tim?
I have the highest respect for Mr. AU N EGL, but are you implying that it's more reliable to weigh other people's cars...........or your own???
Since I've weighed MY cars, on the same scale at the same day, right after one another, with both about 1/2 tank of gas, and know exactly what has been done to each...............that would be more unreliable than seeing other cars getting weighed (with no clue what's really been done to them)????
A look at GM's factory curb weight numbers (which are illegal to incorrectly file with the NTHSA for weights) agree with me. Does anyone need me to post the exact GVW numbers right off my door panels??? This is just plain stupid, as there's only been around a 350lb difference in true stock form. Options will affect than number slightly, but only by a few lbs. A stock WS6 came with pretty much every option already in it, so that's your top number.
I have no doubt that he's seen 3700lbs F-bodies, what he may not have seen was the roll cage, iron block, and full upgraded suspensions.
Old 06-21-2008, 11:18 AM
  #34
David426
David426's Avatar
I remember Car and Driver ran a 13.4 with a stock 2001 Camaro SS.. I think the best for the 99 6sp C5 was 13.2 or 13.3 cant remember which,, Any how it boils down to a drivers race.. The F body 6 speeds will take a C5 A4 with stock 2.73 gears for sure
Old 06-21-2008, 11:31 AM
  #35
FrankTank
FrankTank's Avatar
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Let's keep the comparrison stock for stock. You guys start posting about CAI intakes, cat-backs and headers and that changes everything.
All I'll say is, I've owned both (in six speeds) and the 2 cars are VERY close. The LS1 motor is the same in both cars.
You guys will be debating this until the end of time This is like trying to convince a Democrat to be a Republican and vs a vs
Old 06-21-2008, 11:49 AM
  #36
nj02vette
nj02vette's Avatar
Very fair. The discussion starts out about stock cars, then quickly degenerates into a "that's not what I've seen at the track", which is hardly a good representation of "stock" cars.
I've said from the beginning, the cars are very close, with the edge to the vette.
Old 06-21-2008, 12:35 PM
  #37
Mike Mercury
relax man !!! Just having some fun.
To Why Is A C5 Fast Than A Trans Am
Old 06-21-2008, 12:36 PM
  #38
Mike Mercury
and you could get the 3.15 without the Z51 option.
Old 06-21-2008, 01:20 PM
  #39
MUKAK
MUKAK's Avatar
this tread is going nowhere...
stock for stock the TAs are slower than Mn6 C5 97-2004 pick any year...
any1 dissagrees?
Old 06-22-2008, 02:04 AM
  #40
danziger
danziger's Avatar
any1 dissagrees?
Nobody is disputing that, but the OP wanted to know "why" there is a difference.
Quick Reply: Why Is A C5 Fast Than A Trans Am
