AEM wideband gauge installed! (PIC)
Old 06-16-2008, 01:10 PM
C6Antwon
C6Antwon's Avatar
Default AEM wideband gauge installed! (PIC)
Here is a pic of my recently installed AEM wideband gauge. I didnt want to put a double or triple gauge pod in, because...well...I dont need the extra gauges. I hope this helps some of you thinking about putting gauges in your Vette, but dont want a pod.
So I chose to put it here:
Thanks,
Anthony
Old 06-16-2008, 03:20 PM
LEAVINU
LEAVINU's Avatar
Seems to be becoming a common location for these now. However the last pic I saw of another members location was @ 1" above the vent.
Yours seems to be the top portion of the vent so how was that done? Also is there any issue with heat/cold air blowing on the back of the gauge if it is indeed in the vent?
Nice gauge though- I have thought about one of these a few times.
Old 06-16-2008, 03:57 PM
danl72
danl72's Avatar
Nice.
Old 06-16-2008, 04:40 PM
C6Antwon
C6Antwon's Avatar
1: Take the bezel out of the car that goes around the vent and around the cluster.
2: Remove the air vent held in by 2 clips to the back of the bezel/surround.
3: Take the air vent that you removed and do some modification to it by cutting it in half only leaving 3 of the horizontal vents still intact.
4: Take your gauge and wedge it in the air vent oval. Secure it using the strap from the back that comes with the gauge and the 2 nuts that screw to the back of the gauge.
5: Run all of your hookups and reinstall the bezel and you're done!
I have not noticed any issues with hot/cold air on the back of the gauge. I have even done this to multiple cars that I have had also!
Old 06-16-2008, 07:16 PM
Corpsvette
Corpsvette's Avatar
Nice install but I noticed your breaking the speed limit and almost out of gas
Old 06-16-2008, 08:19 PM
red06c6hm
red06c6hm's Avatar
You have headers for the wideband sensor bung, or did you install it into the cat casing on the stock exhaust?
Old 06-16-2008, 09:22 PM
MrDrezzUp
MrDrezzUp's Avatar
What is great about that install is looks like you only have to cut the vent. Is that correct? If that is correct then returning the car to stock would entail the purchase of a replacement vent, rather then replacing the dash.
Old 06-17-2008, 04:49 AM
C6Antwon
C6Antwon's Avatar
Yes I have Kooks 1 7/8 LT's....I installed the sensor in the rear o2 bung since I have the rear o2's turned off with HPTuners.
Yes you only have to cut the vent! Returning to stock would be as simple as buying a new vent from the dealer, RATHER than replace the whole dash.
Old 06-17-2008, 07:21 AM
Mardis Gras
Support Corvetteforum!
Mardis Gras's Avatar
Nice work with a finished look
Old 06-17-2008, 07:47 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Looks like it belongs there.
Old 06-18-2008, 10:11 AM
C6Antwon
C6Antwon's Avatar
Thanks guys. Everyone that has seen it has said the same thing...."It looks factory!"
Old 06-18-2008, 04:35 PM
n77nxc
ZO6 Owner
n77nxc's Avatar
Killer install...I have the same wideband on mine, and I'm digging your install. I might just have to give it a shot this weekend.
Old 06-18-2008, 07:55 PM
MrDrezzUp
MrDrezzUp's Avatar
I don't know what I like better...how slick this install looks...or that you don't have to carve up your dash or put a plastic A-pillar on!
Again...Great work!
Old 06-18-2008, 11:07 PM
ChargedC6
ChargedC6's Avatar
nice! i have that and the matching aem boost also best gauges IMO.
Old 06-19-2008, 02:49 AM
Sportsdude
Sportsdude's Avatar
Nice install
Old 06-19-2008, 09:15 AM
C6Antwon
C6Antwon's Avatar
Again...Great work!
Old 07-05-2008, 10:12 AM
carlrx7
carlrx7's Avatar
St. Jude Donor '08-'09
ive had my AEM UEGO sitting in my garage for like 2 years now. it was gonna be installed in my previous car but i couldn't find a location to install because it had airbags in the a-pillars. i think im gonna do this when i install my LT's
p.s. do you run cats? or ru using the off-road pipe?
-carl
To AEM wideband gauge installed! (PIC)
Old 07-05-2008, 10:50 AM
C6Antwon
C6Antwon's Avatar
-carl
Im using a borla off-road x-pipe.
Old 03-06-2011, 06:36 PM
Rosspbig
Rosspbig's Avatar
Does this gauge have a dimming feature that dims it when your headlights come on?
Old 03-06-2011, 10:16 PM
Blk 08 C6
Blk 08 C6's Avatar
nice great info.would have to consider this when I go FI and LT headers.
Quick Reply: AEM wideband gauge installed! (PIC)
