Gatorback #4060798 or #4060802 ?
Old 05-17-2008, 07:36 AM
MadTom
MadTom's Avatar
Default Gatorback #4060798 or #4060802 ?
Hi all,
I want to replace the a/c belt and alternator belt by GY gatorback. I have read a lot of posts but I’m unsure which is the correct size of the alternator belt for my 1999 C5.
Also I wonder that there are contradictory statements in different application guides. Some advises #4060798 Gatorback Serpentine 79.875 in. length and others #4060802 Gatorback Serpentine 80.25 in. length for the 1999 C5 alternator belt.
The a/c belt is clearly # 4040420.
Is there really a difference in the belt drive in the different model years ?
Can anybody help and reach clarification ?
Thanks for help in advance
Tom
Old 05-17-2008, 01:18 PM
jrprich
jrprich's Avatar
From Summit I ordered, but have not done the install yet
GTR-4060798
Old 05-17-2008, 01:36 PM
hawk4077
hawk4077's Avatar
That's a good question auto zone just sold me a 4060802 for my 2002 coupe hope it's right
Old 05-17-2008, 02:24 PM
jrprich
jrprich's Avatar
Well if someone figures it out, please post as i would rather not do it twice
Old 05-17-2008, 02:33 PM
jrprich
jrprich's Avatar
From the Goodyear Site
http://www.goodyearep.com/ProductsDetail.aspx?id=3128
Replacement Products for CHEVROLET CORVETTE - 1999 5.7L V 8 Eng
Poly-V Belts
Part No.
4040420 Poly-V, w/AC
4060798 Poly-V, Alt & PS
Old 05-17-2008, 03:25 PM
MadTom
MadTom's Avatar
Thanks , I have found the same information from GY before I started the thread:
http://www2.goodyearbeltsandhose.com...tCarSearch.jsp
But maybe here is anyone who installed this belt size on a 1999 and have practical experience .
Main reason is that I can't get this Gatorback belts in Europe and so I search for a affirmation before I will order the wrong size and won't do it twice
Maybe I will order preventively both belts .
Is there really a difference in the belt drive in the different model years?
Old 05-17-2008, 04:52 PM
2KFRC5
2KFRC5's Avatar
My GM parts manual lists the same # for '97-'01 Gen/PS as 12561501, and '97-'01 AC as 12559326.
These are GM #'s, but they use the same belt for these years. My manual only goes to '01, so I don't know if there were any changes for '02.
Also, I don't know if the export Vettes are different, but my manual doesn't list them as being different in this aspect.
Old 05-17-2008, 05:11 PM
MadTom
MadTom's Avatar
Thanks for research !
# 12561501 was superceded by # 12572188 and it's the same # for '97-'04 .
My Vette is an Europe modell but this makes no difference.
Old 05-17-2008, 06:07 PM
MadTom
MadTom's Avatar
From the Goodyear Site:
# 4060802 Gatorback Serpentine 80.25 in. length
For C5: '97, '98, '02, '03, '04
For C5: '99, '00, '01
puzzlingly
gatorback too short...?
Old 05-22-2008, 08:46 AM
MadTom
MadTom's Avatar
Is anybody there with practical knowledge which Gatorback Alt/PS belt size fits a C5 1999 ?
Thanks!
Tom
Old 05-22-2008, 06:33 PM
MAC5
MAC5's Avatar
Recall looking into the P/S Alt belt differences when I installed the Gatorbacks on my 98 in 2005. The 4060798 belt was only used from 99-01, the reason was either a different size pulley on either the P/S pump or the alternator. Interestingly they went back to the 4060802 belt in 2002.
Old 02-27-2012, 09:44 PM
Vette_Fan
Vette_Fan's Avatar
It's a funny thing for guys with 1999 Vettes......we're like the Black Sheep, we don't get a straight reply...lol.....
I guess I'm just gonna get the 4060798... who knows...it "may" work
Old 07-29-2012, 08:50 PM
Rocket1999
Rocket1999's Avatar
Did the 4060798 belt fit on the 99? Just looking for some one with a 99 that says they were able to get this one on before I order. Thanks
Old 07-29-2012, 09:56 PM
dadvan99
Support Corvetteforum!
dadvan99's Avatar
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Goodyear 4060798 Gatorback Poly V-Belt is what I ordered and installed on my 1999 this past winter.
Old 07-29-2012, 10:06 PM
pickleseimer
pickleseimer's Avatar
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
I researched this many moons ago, so I'm pulling this out of deep memory. I seem to recall that some years had a 'clutch' in the alternator pulley - don't recall which years. Apparently the 'clutch' was to prevent the alternator from being oversped, but again I'm not sure. Anyway, the alternators that had this so-called clutch used the 802 belt and the alternators with no 'clutch' used the 798 belt. Sure hope someone can corroborate this for you.
Old 07-30-2012, 08:10 AM
sunchaser73
sunchaser73's Avatar
Here are the belts I use. The dimensions should be the same for other brands:
1) accessory drive belt - 13/16" x 80-3/8" (20mm x 2040mm) OC
Gates/CarQuest Micro-V AT p/n K060798 [$30.49/ea]
2) a/c compressor drive belt - 9/16" x 42-5/8" (14mm x 1084mm) OC
Gates/CarQuest Micro-V AT p/n K040420 [$19.39/ea]
My C5 is a 1999...
Old 07-30-2012, 08:35 AM
tonio76
tonio76's Avatar
Just replaced mine last week, 4060798 from Amazon for my 99 Vert. Fits perfect and no more crickets in the engine compartment
To Gatorback #4060798 or #4060802 ?
Old 03-23-2013, 10:44 AM
getawaycar
3rd Gear
getawaycar's Avatar
I just ordered the 4060802 for my 98 vert. Ive gone through 3 belts now. changed out the harmonic balancer, the tensioner and the tensioner for the AC plus the AC belt. still chirps. if this doesn't work, Im going to ramp the car off into a ravine. will post the results later.
Old 03-23-2013, 11:51 AM
dadvan99
dadvan99's Avatar
Oldtimer
I replaced mine last year using #4060798 for my '99. Did a 3 week, 7250 mile road trip after replacing it with no issues.
Old 03-23-2013, 12:03 PM
getawaycar
3rd Gear
getawaycar's Avatar
I pray that I can get the same results. For those still suffering, the only real temporary fix is to put baby powder on the belt every 200 miles or so. belt dressing doesn't work (and neither does wd40 like I read somewhere else). I read something about using comet cleanser and that it would use detergent like action to silence then clean the pulleys, but it didn't work for me. I use baby powder now because I can get a travel size bottle at the store for a buck and it fits in my console
Quick Reply: Gatorback #4060798 or #4060802 ?
