C5 Ignition Switch Repair
Old 03-15-2008, 08:04 PM
TTK98
TTK98's Avatar
What a guy ! The man deserves an award for all this stuff. Thank you once again Bill for the time you take with the detailed fixes you post.
This one had no better timing as the car started really acting goofy lately such as dying for no reason. Key on and gauges would not sweep as normal and more. I was about to order a new switch and spotted this post. Just finished pulling the thing and sure enough pitted/nasty conacts. I used one of my wifes disposable emory boards (nail file thingy) cut down to fit and cleaned them up. Bent the arms of the conacts for greater pressure just you suggested and viola like new!
I also went one more step and removed the key pellet contact piece in the front of the lock cylinder just out of curiosity. It is a clear plastic piece housing two spring contacts which press against the pellet when inserted which does not look servicable (not sure if pressed together or glued?) I did monitor the action of the key with a vom and wiggle tested with no intermitent opens.
Time will tell if all is well. Thanks again Bill, you made my day. Tom.
CorvetteBrent (09-12-2018)
Old 03-18-2008, 01:48 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Tom
Thanks for the good words. I still need to add in some more data. Hopefully I be able to after I finish all my projects/
BC
Old 03-20-2008, 02:08 AM
SinghZvette
SinghZvette's Avatar
Where is the ignition switch located? This might be IT (evil laugh) .. my electrical gremlin that has been hounding me for months!!
Old 03-20-2008, 01:21 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its right behind the thing that you stick your key in every morning! The key cylinder is inside that switch. You need to remove the close out panel from under the dash and the center console cover! There it be!!
Hope this helps.
BC
Old 03-20-2008, 02:29 PM
SinghZvette
Hope this helps.
BC
Bill, Thnkx for your reply. I was told that the ignition switch might be attached to the steering column and a PITA to get to :o Some of us here on the Forum are working very hard to learn from the elite group of experts such as you . You are my hero and using your posted instructions I hope to add another success story to this post, hopefully promoting it to sticky status one day.
Old 03-20-2008, 03:37 PM
1KLRTOY
1KLRTOY's Avatar
I want to thank you for your post on the ignition switch repair. I can't tell you how much it helped in tracking down the source of the dreaded "service traction control and active handling" The codes were P1571,P1689,C1277 and IPC & SDM U1040 also cleared was B0432 rear defog ckt. I would have never suspected the switch without you taking the time to figure it out and then to take the time to post your repair procedure in detail. I replaced my switch (ordered from Gene) and then checked the old switch and found 3 burned contacts. All the codes have cleared and not returned. My guess that these switches are the source of a lot of the C5's electrical gremlins. By the way mine is an 01 with 70k and a daily driver and that adds up to a lot of cycles on the switch. My hats off to you Bill, thank you so much for all your help Ron R.
The following 2 users liked this post by 1KLRTOY:
Castor (11-12-2021), CorvetteBrent (09-12-2018)
Old 03-20-2008, 04:17 PM
SinghZvette
I am ready to remove and clean the contacts on my ignition switch. Are there any precautions to be taken before disconnecting and when connecting the ignition switch on my 98-coupe? I am worried about the anti-theft alarm kicking in and disabling the car. Any advice would be good
Old 03-20-2008, 05:57 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES!!!!!!!!!!!! Disconnect the NEGATIVE battery cable from the battery before you remove ANY electronics and when your done reconnect it, and then clear and DTCs that may have popped up during the reconnect. Retorque the battery terminals to 11 ft/lbs for 97-2003 C5's
BC
Old 03-21-2008, 12:59 AM
SinghZvette
ANOTHER SUCCESS STORY
Found the worst electrical gremlin hiding in my ignition switch. Took me in all 2 hours, from start to finish using Bill's instructions, and all codes are gone.
I've circled the failing contacts ..
and the final result
Time for a chilled beer and some spicy peanuts Bill I am having another in your name .. you are my hero!!
Old 03-21-2008, 01:57 PM
Mac11
Mac11's Avatar
BC hits another one outta the park! Looks like "Sticky" material to me!
Old 03-21-2008, 02:35 PM
SinghZvette
If we are taking votes for a sticky status on this post, I am IN.
I spent close to $800 (replacing shocks, using F45 sims, labor) till I found that the problem was the d**n ignition switch, which cost me nothing to fix, thanks to BC's post. I did endup losing my F45 shocks which were all good to begin with. I would have ended up shelling more $$$'s had it not been for this post .. now I can use the money saved to buy me some mod goodies
Old 04-09-2008, 10:27 AM
saw22
saw22's Avatar
Bump this up! I am having a similar problem here and took the time to check my switch thoroughly today. See post #7 especially:
http://forums.corvetteforum.com/show....php?t=1991852
My advice is to follow these instructions to the letter. It is a very simple task. I'm honestly ashamed to admit that I almost didn't take the time to recondition this switch!
Old 04-09-2008, 01:10 PM
  #33
J.R.
J.R.'s Avatar
Default switch
Bill,
I have just started to have intermittent issues related to starting, shutting off etc.
Your info has probably saved me untold hours of time plus frustration.
Thanks so much for your detailed information.
J.R.
Old 04-13-2008, 06:06 AM
  #34
Junkman2008
Junkman2008's Avatar
ttt because the info here is priceless!
Old 04-13-2008, 05:00 PM
  #35
Curby
Curby's Avatar
Cruise-In VII Veteran
St. Jude Donor '06
Just did this fix on my 2000 convertible. I have a little over 68,000 miles on it and the contact looked just like the pictures above.
This is why the forum is a great place to go for help.
Old 04-18-2008, 12:01 PM
  #36
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Excellent. Hope this post keeps helping people!
Old 06-24-2008, 08:45 PM
  #37
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
In an effort to help other people with their WEIRD electrical issues, I'm bumping this post TTT and also linking this MAGNIFICENT and VERY INFORMATIVE post generated by another talented and truly amazing forum member MIKER (Mike)
It details how to repair the Headlight Switch (multifunction switch) in excellent detail.
The combination of these two self repairs will save us TONs of cash!!!
http://forums.corvetteforum.com/show...adlight+switch
To C5 Ignition Switch Repair
Old 07-13-2008, 08:42 AM
  #38
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ttt
Old 07-13-2008, 11:28 AM
  #39
DeeGee
DeeGee's Avatar
What a great post Bill
I just hope I never need to use it
Fantastic info
vetintheblood (11-20-2020)
Old 07-13-2008, 04:32 PM
  #40
Midnight Rambler
Midnight Rambler's Avatar
Originally Posted by RON NARDONE
What Do You Figure A Repair Like That Would Cost At The Dealer???
About $280, including parts and labor...And that's not including the tow to the dealership...:o
Thanks Bill!
HeyVern (11-15-2021)
Quick Reply: C5 Ignition Switch Repair
