ALERT: DexCool Coolant! READ!
Old 12-18-2007, 01:11 AM
  #61
dmoore
dmoore's Avatar
Gee what else can go wrong with the C5s?
Old 12-23-2007, 11:18 AM
  #62
MikeyTX
Support Corvetteforum!
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by OGC5
Horse Pucky! Lawyers continue to collect names for potential class action lawsuits from people claiming Dex-Cool damaged their car.
Prestone and other suppliers offer a Dex-cool which is an organic based mixture in addition to the Propylene Glycol based stuff. All have anti corrosion additives and can be mixed together although not recommended. Prestone and GM have experienced engineers and I doubt that they would fill the Corvette at the factory with a defective mix. They do however use Kentucky Tap water to mix with the coolant so I drain and refill with distilled water and 50% Dex. Darn stuff is always clean although I do refill every two years as I am a typical Obsessive Corvette owner. The average driver idiot out there probably does not even know where the Radiator cap is located.My 2 cents.
OGC5
What's wrong with Kentucky Tap water ? Some of the most gorgeous women I've met come from Kentucky. Drinking the water sure as heck didn't hurt them.
Old 12-23-2007, 02:39 PM
  #63
bmacZO6
bmacZO6's Avatar
This is very old news and if you read both side of this issue you will see more positive reports than negative. 14 lawsuits for 40 million vehicles is not a very high percentage.
Old 12-23-2007, 03:45 PM
  #64
JPEAK
JPEAK's Avatar
Originally Posted by jacks996
When I change mine I use dexcool and distilled water and my engine and radiatior look new inside
I think the secret is to change when recommended every 5 years and use distilled water.
Old 12-23-2007, 05:08 PM
  #65
FLACHUSNRET
FLACHUSNRET's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16
You should always use distilled water when adding to your radiator or car battery. Distilled water does not contain minerals that can build up and create problems thousands of miles down the road.
Old 05-04-2008, 01:09 AM
  #66
BoiseVette
BoiseVette's Avatar
Originally Posted by 10U 99
what do you need if you have 3 lawyers buried up to their necks in sand?
A LAWN MOWER!!!
Sorry to open an old thread.
Old 05-04-2008, 01:47 AM
  #67
PierEagle
PierEagle's Avatar
Originally Posted by Mike Mercury
certainly.
Had lawyers been around during the creation... as soon as God said "let there be water"... some lawyer would of filed a class-action lawsuit about the existence of water... with all sorts of "data" to justify the legal undertaking.
GM will probably settle this for "nuisance value" of which DexCool users will get a $1.50 off coupon for their next purchase and the "lawyers" will get $25mil for their "pain and suffering".
Old 05-04-2008, 02:10 AM
  #68
RLYSLO
RLYSLO's Avatar
St. Jude Donor '08
Originally Posted by z06Bigbird
Many owners of GM's 3.1 and 3800 engines have found the need to replace the intake manifold gasket. A friend of mine who specializes in selling used GMs says he changes the intake gasket on every GM he sells (prior to sale).
Very true. I had a 3.8L 2001 firebird and the intake gasket failed which got air into the system and I got the lovely brown gunky mess that resulted from that mixing with the dexcool.
It wasn't a dexcool issue. it was a gasket issue. anyway, I had an extended warranty on it so they replaced the gasket, flushed everything out, installed new lifters, flushed the oil several times... and then promptly wrecked my car and totalled it when they test drove it after the repairs...
I don't believe that dexcool is the problem at all... just bad gaskets.
Old 05-04-2008, 02:28 AM
  #69
jornahow
jornahow's Avatar
The following link provides more balanced information and supports what most have been saying in this thread.
http://www.getahelmet.com/jeeps/maint/dexcool/
Old 05-04-2008, 02:48 AM
  #70
dobewillie
dobewillie's Avatar
dex cool ok deionized water a big nono
Old 05-04-2008, 11:25 AM
  #71
Husker67
Husker67's Avatar
I don't think so!!
Old 05-04-2008, 11:46 AM
  #72
Tigershark3
Tigershark3's Avatar
Just changed my Dex Cool after 2 years... I put the new and the old stuff side by side. The only difference was a slight color difference. System looked clean. I used Havoline Dex Cool w/ distilled water plus water wetter. I do think that leaving Dex cool in for long periods Could cause problems. My sons '97 Gran Prix had old Dex cool in it when we bought it and it was a mess - lumpy crap. I say change every 2 years and don't mix the green and Dex together regardless of what they say. $.02 deposited.
Old 05-04-2008, 12:07 PM
  #73
MagneticRed1977
MagneticRed1977's Avatar
I change every five years as recommended.
Old 05-04-2008, 01:10 PM
  #74
GettReal
GettReal's Avatar
This is the right way to do it 50/50 mix and you wont see any issues.
Old 05-04-2008, 01:45 PM
  #75
Mike Mercury
Mike Mercury's Avatar
the lawyers in this class action lawsuit will get millions... the people they were championing for l will get checks for 87 cents.
I imagine every mfgr - of any product - eventually finds themselves at the end of a class-action lawsuit. It's not the "filed lawsuit" that should get everyones attention... it's the merit of the case... and the motive of those filing the court action. Only there will the real facts be found.
Old 05-04-2008, 02:01 PM
  #76
1sickz51vette
1sickz51vette's Avatar
My dex cool turned to crap and most likely caused my radiator to crack! i will be ordering one today, hopefully it won't be too bad to install myself.
Old 10-11-2008, 10:50 AM
  #77
Rocketman@ameritech.
1st Gear
Rocketman@ameritech.'s Avatar
Default coolant age and car miles
I have a 99 corvette with 10,000 miles on it. Iv'e never changed the coolant on it and the dealer recently said that the coolant was just starting to change color. They did'nt mention any damage to the radiator or anything else. Should my car be OK? -J.T.
To ALERT: DexCool Coolant! READ!
Old 10-11-2008, 10:55 AM
  #78
angman5
angman5's Avatar
This is True I am in the A/F Recycling business and it will corode your motor. I changed over to the green stuff in 2001
  #79
rws.1
rws.1's Avatar
120K + (s)miles on my '01 Vert with Dexcool. No cooling system issues... still on original hoses.
Old 10-11-2008, 12:31 PM
  #80
ljthe2nd
ljthe2nd's Avatar
the mileage in this case doesn't matter it's the age. You're coolant is at least 9 years old. You need to flush the system and put in new.
Quick Reply: ALERT: DexCool Coolant! READ!
