after market rectangular headlights
any one else have lights like these??
I am having a problem with mine. I bought the car like this but only the 2 inner ones light up. In order to get my inspection the mechanic says they all have to work. Is this a stock wiring set up or do I have to do some modifications to the wiring to get it to work? the lights seem to change to high beam when I step on the pedal. but still only 2 light up. They are all connected but still no go. Do I have to have specific lights to go in here? (probably).
If any one has installed these could you please let me know what I need to do to get them to work properly? any info would be greatly appreciated.
Peace
Peace
Yes, I had those for years, they fine, and a total stock wiring setup....most likely your lo beams are burnt out...you maybe able to find a connection under the dash...like a loose plug on the dimmer switch, especially if it's on the steering column...but doubtful that's it IF you have a good solid snap when either switch is pushed....later sharks had it on the wheel, early had it on the floor....
I suspect the bulbs need changing...they cheep at a AZ/etc....
not hard to change either...maybe take a resistance/continenuity check across the terminals to be sure, but I bet they bad...common enough...
