1966 stock size steel wheels
Old 05-06-2007, 08:01 PM
Randy C
Cruising
Randy C's Avatar
Default 1966 stock size steel wheels
I am just in the process of blasting and painting the wheels on my 66 and it turns out that they are 15 x 5.5's. is that correct for the stock steel 1966 wheels?
Old 05-06-2007, 08:44 PM
vettes1st
vettes1st's Avatar
St. Jude Donor '06
Yes!
Old 05-06-2007, 08:45 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Yes. 63-66 are 15 X 5.5 and the 67 ralley's are 15 X 6. KO's are 15 X 6.
Old 05-06-2007, 09:22 PM
Randy C
Cruising
Randy C's Avatar
Thanks!
Old 07-14-2007, 05:41 AM
Nev Williams
Nev Williams's Avatar
Would anyone happen to know what the offset is supposed to be on these? Is this measured to the very outer edge of the rim?
When car is jacked up at rear with daylight under between the tyre and floor I have the transverse spring end interfering with the RH rear rim.
I'm just wondering if the rims have the correct offset.
Neville
Old 07-14-2007, 10:52 AM
66since71
66since71's Avatar
Spring shouldn't interfer.. If no one has the data handy, I'll dig out my original rims and measure them for you.. I'll follow the thread..
Old 07-14-2007, 11:37 AM
66since71
66since71's Avatar
back spacing should be 3 5/8" (just measured my originals)
That is measured from the inner most edge of the rim to the mounting surface.
Old 07-17-2007, 03:25 AM
Nev Williams
Thanks for this.
I will measure wheel, when it comes back from Compliance test and add to thread. They also picked up this wheel interference and reckon the spring is not centred. It looks centred to me. They seem to think it is just a matter of moving the spring. I do not think it is as simple or as easy as this somehow
Neville
Old 07-17-2007, 12:31 PM
toddalin
toddalin's Avatar
Received 1,167 Likes on 486 Posts
Originally Posted by Nev Williams
Thanks for this.
Neville
As I recall, there is a small hole in the center of the spring with a nut/bolt that holds the spring elements together. The bolt fits into a small locating hole when the spring is mounted. Any side to side movement will be extremely small (<1/8") due to this locator.
Sounds like you need a shop that knows Corvettes.
Old 07-18-2007, 01:27 AM
Nev Williams
All sorted in no time.
I will get to see tommorow when I get to pick the car up, all registered to legally drive on our roads Yeeehaaaa.
I have of course driven it illegally but now I can go down a decent stretch of highway and have some fun and no doubt also find out a few other things that need fixing.
I'm sure the wheels need aligning but that will have to wait until I install all the new bushes etc.
Old 07-21-2007, 06:33 PM
Nev Williams
Have measured the offset
102mm (4") If your wheels are orig standard that makes mine from something else. That extra 30mm (3/8") is obviously making clearances to tight. With a forty year old car these wheels could be off any GM car.
This might be a good time to start thinking replacing with a nice set of alloy wheels and tyres !!
Old 12-03-2012, 08:36 PM
aussievett
1st Gear
aussievett's Avatar
1966 tyre sizes, I am looking to buy some white wall tyres will 215/70/15 fit on my 66 vett without rubbing or should I go 205/75/15 they are steel wheels. What looks the best?
Old 12-03-2012, 11:57 PM
Hitch
Hitch's Avatar
WOW a thread that is 5 years old!!!!!! lol
Old 12-04-2012, 08:04 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Either size will work - however, with 205/75's, there is ZERO chance for any rubbing under any circumstances. With 215/70's, rubbing is possible at full steering lock and suspension compression (like entering a driveway).
Old 12-10-2012, 07:49 PM
anglerjon
anglerjon's Avatar
I put 205/75s on mine, think it looks about right, could be a little tight with 215x70s
To 1966 stock size steel wheels
Quick Reply: 1966 stock size steel wheels
