CD player error
Old 02-17-2007, 01:55 PM
rtagz
rtagz's Avatar
Cruise-In IX Veteran
Default CD player error
anyone encounter problems with their cd player not reading discs. any disc that i load is not being read, err flashes on the display and the cd is ejected. anyone have a clue?
Old 02-17-2007, 02:15 PM
claysmoker
claysmoker's Avatar
St. Jude Donor '09-'11-'12-'13-'14
If they are burned discs and not factory, some brands of disc won't work. I've had the same problem.
Old 02-17-2007, 02:27 PM
Frozenfire
Frozenfire's Avatar
You didn't say whether you had the changer in the trunk. That's the only unit that gave me an error message. Probably had condensation on the discs or the carrier wasn't seated properly.
Old 02-17-2007, 02:38 PM
rtagz
rtagz's Avatar
in dash factory cd player, and all discs originals and burnt
Old 02-17-2007, 02:45 PM
Frozenfire
Frozenfire's Avatar
Hmm. I'm assuming it worked OK prior to this episode? When inserting the CD did you push it in a little and let the mechanism take the disc in, or did you try to force it? If you try to force it you'll get an error message. (OK, let the dirty minds take their turn! )
Old 02-17-2007, 02:49 PM
rtagz
rtagz's Avatar
nothing out of the ordinary as far as that goes. it just will not read anything, and says err.
Cali Corvettes (06-14-2023)
Old 02-17-2007, 04:38 PM
artfahie
artfahie's Avatar
Try dis-connecting your battery so it can "re-boot" itself... I had the same thing happen once, no big deal... I think it's how I handled it. Good luck.
Old 02-17-2007, 04:40 PM
Bounty Hunter 6
Bounty Hunter 6's Avatar
Don't have to disconnect the battery, just pull the fuse (it's in the engine compartment fuse box, not inside the "cockpit." Wait 20 minutes and put it back in. This "resets" the head unit.
CorvetteBrent (01-24-2021)
Old 02-17-2007, 04:45 PM
korte
korte's Avatar
Make sure that you remember your anti-theft code before you pull power (if you made one) or it'll be locked up!
Old 02-17-2007, 05:00 PM
97C5driver
97C5driver's Avatar
This has been an increasing problem here. But the fact is, your screwed man.
You have to either get a replacement stock unti or go aftermarket. (or pay a rediculous amount to have your unit fixed).
My unti was reading "err" only occasionaly. then it got worse, and worse, and worse. It was driving me crazy. I finally found a stock replacement for a good price. you can get one for around $100-140. If you go aftermarket you have to replace the whole system or spend approx. $350.00 for the neccessary adapters to use your existing bose system with an aftermarket headunit.
it sucks man. good luck.
Old 02-17-2007, 05:58 PM
BUBBAS 01Z06
BUBBAS 01Z06's Avatar
Get a compressed air can ...
Just like the ones you can buy to clean your keyboard...give that a shot in the CD slot...sometimes the mechanism that reads the CD gets dirty !!
Could be a cheap fix !
Cheech Wizard
Cheech Wizard's Avatar
Location: Orlando, Florida, MY Corvette is BEST Corvette because MID-ENGINE!
I had that problem when the player was set to "shuffle" and the weather was hot (over 85 degrees)....but ONLY under THOSE conditions.
I now have an Alpine HU...much better!
Old 02-17-2007, 11:15 PM
korte
korte's Avatar
You have to rewire the whole thing.
Old 02-18-2007, 09:16 AM
vpunteney
vpunteney's Avatar
My 01 with 12k on it has never taken burned CD's in the head unit. I don't have the changer. All store bought work fine, it was the same in a couple of my other cars as well. I never knew if I needed to switch brands of disc's or if it was normal. I now have a MP3 player which fixed everything.
If there is an easy fix, or if a certain kind of disc works, please let me know.
Vinnie
Old 10-22-2011, 05:59 PM
marcs50th
marcs50th's Avatar
Default Err on CD 12 player CD for 2003 Corvette
I have 2003 50 A/E Corvette and do not drive it that much, well today I took it out and I wanted to play a cd from cd changer, and I received the following Err on the radio. I tried all the recomentations but nouthing worked. Can someone help me out on this....
Old 10-23-2011, 11:25 AM
mjwitte
mjwitte's Avatar
Are the CD's right side up in the changer cartridge? The first time I used my changer, I set the CD's on the trays label side up - the label is supposed to be on the bottom when you set the CD on the cartridge tray. It will give you the same ERR message if you do this.
Old 10-23-2011, 06:48 PM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
If your having issues with Store bought CD's and Home made CD's then read my procedure how to clean the laser. I bet it will fix your issues. It has on mine and many others.
My web page:
www.ToqueZ06.com
Scroll down to the bottom and click on
C5 Corvette - CD Player Laser Cleaning Procedure:
If your only having issues with Home made CD's then when you burn the home made CD set it up to burn as SLOW as possible. It worked for me.
Good luck !
Toque
The following 3 users liked this post by Toque:
CorvetteBrent (01-24-2021), helphos (11-22-2018), mike5511 (10-04-2020)
To CD player error
Old 10-23-2011, 06:51 PM
Toque
Toque's Avatar
I highly suggest to take your 12 disk apart to clean the laser.
The laser just gets a build up of crud on it from over the years. It happens on the head unit too like my procedure above details.
Toque
Old 10-23-2011, 06:55 PM
Toque
Toque's Avatar
He is not screwed at all .... just a dirty Laser. Easy fix !
I hope you still have your original head unit.
Clean the laser like my procedure above details and I bet it fixes it.
Your issue is text book for a laser getting dirty over time. Mine was the same.
Toque
Old 10-24-2011, 11:58 AM
AngryTurtle
AngryTurtle's Avatar
Well thats just not true.
Quick Reply: CD player error
